January 25, 2013, 05:03 |
struggles with adopted solver
Anja Miehe
Rep Power: 16 |
Hello everyone,
I would like to use PyFoam with my own adopted solver, especially pyFoamPlotWatcher.py. The run of my solver put in run.log goes well and looks as follows for the beginning (first 3 steps): Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : castFoam Date : Jan 25 2013 Time : 09:43:48 Host : "hugo163" PID : 8714 Case : /home/anja/OpenFOAM/Zeitverhalten/galliumMelting/castFoam_Nikrityuk_2D_200x280_GAMG nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading field T Reading field p_rgh Reading field U Reading field Us Reading/calculating face flux field phi Reading thermophysical properties Calculating phase change properties Calculating field g.h Courant Number mean: 0 max: 0 PIMPLE: Operating solver in PISO mode Starting time loop Time = 0.0015 Fourier Number max: 0.151337 Courant Number mean: 0 max: 0 deltaT = 0.00151 DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 2.23561e-14, No Iterations 221 SUM SUBCYCLE: Solving for fl, Initial residual = 0.3, Final residual = 7.95519e-07, No Iterations 37 GAMG: Solving for p_rgh, Initial residual = 0.999987, Final residual = 0.00292191, No Iterations 3 GAMG: Solving for p_rgh, Initial residual = 0.00146465, Final residual = 1.44968e-05, No Iterations 4 time step continuity errors : sum local = 1.21777e-17, global = -1.65627e-28, cumulative = -1.65627e-28 GAMG: Solving for p_rgh, Initial residual = 1.50414e-05, Final residual = 9.65508e-07, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 1.05392e-06, Final residual = 9.84715e-09, No Iterations 14 time step continuity errors : sum local = 8.31164e-21, global = -1.65624e-28, cumulative = -3.31251e-28 ExecutionTime = 3.84 s ClockTime = 4 s Time = 0.00301 Fourier Number max: 0.152345 Courant Number mean: 5.34575e-15 max: 5.60951e-13 deltaT = 0.00151 DILUPBiCG: Solving for T, Initial residual = 0.161344, Final residual = 3.27402e-13, No Iterations 6 SUM SUBCYCLE: Solving for fl, Initial residual = 5.56863e-07, Final residual = 5.56863e-07, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.591175, Final residual = 0.000593465, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.000388587, Final residual = 2.57464e-06, No Iterations 7 time step continuity errors : sum local = 8.24014e-12, global = -7.44436e-23, cumulative = -7.44439e-23 GAMG: Solving for p_rgh, Initial residual = 2.73173e-06, Final residual = 5.12553e-07, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 5.33079e-07, Final residual = 2.78747e-09, No Iterations 4 time step continuity errors : sum local = 8.4972e-15, global = -7.44374e-23, cumulative = -1.48881e-22 ExecutionTime = 4.32 s ClockTime = 4 s Time = 0.00452 Fourier Number max: 0.152345 Courant Number mean: 1.24449e-12 max: 1.6071e-10 deltaT = 0.00151 DILUPBiCG: Solving for T, Initial residual = 0.07852, Final residual = 4.32404e-13, No Iterations 301 SUM SUBCYCLE: Solving for fl, Initial residual = 0.0908314, Final residual = 0.00767244, No Iterations 50 ### WARNING: fl subcycle reached maximum iteration of 50 ### GAMG: Solving for p_rgh, Initial residual = 0.154253, Final residual = 0.000309045, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.000270045, Final residual = 1.36153e-06, No Iterations 7 time step continuity errors : sum local = 6.01094e-12, global = -1.4204e-22, cumulative = -2.90922e-22 GAMG: Solving for p_rgh, Initial residual = 1.4531e-06, Final residual = 6.57162e-07, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 7.37195e-07, Final residual = 8.89573e-09, No Iterations 5 time step continuity errors : sum local = 3.74236e-14, global = -1.42041e-22, cumulative = -4.32963e-22 ExecutionTime = 8.43 s ClockTime = 8 s Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : castFoam Date : Jan 25 2013 Time : 09:43:48 Host : "hugo163" PID : 8714 Case : /home/anja/OpenFOAM/Zeitverhalten/galliumMelting/castFoam_Nikrityuk_2D_200x280_GAMG nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading field T Reading field p_rgh Reading field U Reading field Us Reading/calculating face flux field phi Reading thermophysical properties Calculating phase change properties Calculating field g.h Courant Number mean: 0 max: 0 PIMPLE: Operating solver in PISO mode Starting time loop Time = 0.0015 Fourier Number max: 0.151337 Courant Number mean: 0 max: 0 deltaT = 0.00151 DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 2.23561e-14, No Iterations 221 SUM Can anyone help me with a work around? I would love to see the residuals of the SUBCYCLE as well, and I can change that line to a different pattern, if necessary. Or would costumRegexp help? Thank you very much in advance Regards, Anja |
January 25, 2013, 07:46 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
linearRegExp="^(.+): Solving for (.+), Initial residual = (.+), Final residual = (.+), No Iterations ([0-9]+).*$" The SUBCYCLE is not found because your output has one space more before "Solving" than usual and regular expressions are a bit picky there. You could make it more tolerant with Code:
linearRegExp="^(.+): +Solving for (.+), Initial residual = (.+), Final residual = (.+), No Iterations ([0-9]+).*$"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
January 26, 2013, 07:50 |
Anja Miehe
Rep Power: 16 |
Dear Mr. Gschaider,
Thank you very much for the reply. I deleted the additional space before "Solving for fl" and changed the LinearSolverLineAnalyzer.py as you said. It works perfectly. |
own solver, pyfoam, pyfoamplotwatcher.py |
Display Modes | |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 10:52 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 07:58 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
Using a user-defined solver in OF | ozzythewise | OpenFOAM Running, Solving & CFD | 3 | February 8, 2011 16:28 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 15:08 |
