[swak4Foam] is it possible to write a simple program in groovyBC according to C++ language?
Like Tree1Likes
  • 1 Post By gschaider
Old   February 3, 2013, 05:42
Default is it possible to write a simple program in groovyBC according to C++ language?
immortality's Avatar
Ehsan
immortality is on a distinguished road
the condition?expression1:expression2 makes limitations for me.I need more freedom in conditions.are we limited to groovyBC syntax or exists a way to extend this to if-elseif-else conditions?i need to set several conditions for all fractionExpression,valueExpression and gradientExpression.
immortality is offline   Reply With Quote
Old   February 4, 2013, 00:44
Ehsan
i need to be certain.any answer?
Old   February 4, 2013, 04:13
Assistant Moderator
Bernhard Gschaider
You're not serious with that question, right? Of course you can do if-elseif-cascades:
 cond1 ? val1 : (cond2 ? val2 : val3)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 4, 2013, 04:26
Ehsan
i said a simple example.my bc's are unfortunately much complicated.it should include sub or supersonic and inflow or outflow conditions at each patch.thanks.
Old   February 4, 2013, 14:37
Assistant Moderator
Bernhard Gschaider
Where? Not in this thread
There is no simpler example
Modularize the expressions to make them more readable with variables. A sketch (fill out the dots yourself):
variables (
  "isSupersonic= .....;"
  "isInflow= .....;"
  "superSonicInVal=....;"
  "subsonicInval=.....;"
valueExpression=isInflow ? ( isSuperSonic ? superSonicInVal : subsonicInval) : ...";
fractionExpression= isInflow ? ....";
That should make it readable and consistent.
immortality likes this.
Lid-Driven cavity flow with SIMPLE method luckyxu Main CFD Forum 6 November 9, 2011 07:17
Comparison between C/C++ and Fortran? rick Main CFD Forum 45 September 6, 2011 00:52
Simple CFD program John Main CFD Forum 0 March 29, 2003 17:39
The computer language for CFD Ringo Main CFD Forum 50 October 8, 2002 11:14
How to write a simple program ?? kokey FLUENT 0 March 19, 2002 10:21
