-   OpenFOAM Community Contributions (https://www.cfd-online.com/Forums/openfoam-community-contributions/)
-   -   [PyFoam] plotting residuals with different line types or points and fewer variables (https://www.cfd-online.com/Forums/openfoam-community-contributions/115097-plotting-residuals-different-line-types-points-fewer-variables.html)
gustavo_nicknich March 23, 2013 17:18
Hi everyone,
I'm using pyFoamPlotWatcher and pyFoamPlotRunner to plot the residuals. Problem is I need to use those graphs in a paper, so I can't use colors to differentiate between variables. Rather I would like to use different line or point types available in gnuplot.
Also I would like to plot fewer variables. For example, I'm using viscoelasticFluidFoam that solvers for three components in U and six components in tau. Plus p, it makes ten, resulting in a very messy plot.
Best regards.
aljazari March 23, 2013 18:56
I can see from the options for pyFoamPlotWatcher that there is one for custom regular expressions, maybe that can be used.
What I would do is use the option: --write-files
pyFoamPlotWatcher.py --silent --write-files --hardcopy --solver-not-running-anymore log
This will create a folder called log.analyzed with files for different variables, you can then use your favourite plotting tool on these files.
gschaider March 23, 2013 19:59
Originally Posted by gustavo_nicknich (Post 415915)
Hi everyone,
Best regards.
aljazari option is one way to do it. The other would be to write a customRegexp that only scans for the residuals you're interested in (just because they are plotted once doesn't mean they can't be plotted once again)
I see your problem with the styles, but that is not so easy to fix (especially for the predefined plots=
gustavo_nicknich March 24, 2013 14:42
I've used aljazari's option with gnuplot and it worked just fine, thanks!
Luckily I was able to avoid regular expressions, since I'm not familiar with it.
Best regards.
gschaider March 24, 2013 18:00
They're not that complicated. And very useful (not only in PyFoam, but also in regular OpenFOAM for flexible specifications of boundary conditions)
gustavo_nicknich March 24, 2013 19:46
Benhard, could you please indicate some material about using regular expressions in OpenFOAM?
gschaider March 25, 2013 06:20
Well. In dictionaries you can use regular expressions instead of keywords and requests matching that expression will give that result. See for instance http://www.cfd-online.com/Forums/ope...tml#post273069
gustavo_nicknich March 25, 2013 07:46
Thanks, I'll take a look at that.
