[swak4Foam] groovyBC problem with radiation boundary
Like Tree2Likes
  • 1 Post By gschaider
  • 1 Post By sahas
Old   April 29, 2013, 06:24
Default groovyBC problem with radiation boundary
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
I am trying to use the following boundary condition with groovyBC:
k*dT/dn = h*(T-Tinf)+(sigma*emissivity)*(T^4-Tinf^4)
where,
k= thermal conductivity=5.91 [W/mK]
h = heat transfer coefficient =12.4 [W/m2K]
Tinf =300K
emissivity=0.775
What happens in my case is that the simulation diverges after some time steps. Does anyone implemented this boundary condition in OpenFOAM? or any idea how to solve this problem???
Thanks in advance.
ahmmedshakil is offline   Reply With Quote
Old   April 29, 2013, 11:18
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by ahmmedshakil View Post
where,
Tinf =300K
emissivity=0.775
Thanks in advance.
Have you analyzed HOW it diverges? My guess is that it starts oscillating because it over/undershots Tinf. Try smaller timesteps.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   May 3, 2013, 08:59
Thanks gschaider,
yes it's because of time steps. When I minimize the time steps the problem solved
Old   May 4, 2013, 07:12
Assistant Moderator
Bernhard Gschaider
Thanks gschaider,
OK. You can stabilize it by implementing a mixed boundary with TInf as the Dirichlet-term (that would avoid overshooting). The fractionExpression is to be calculated according to the heat-flux
Old   August 31, 2013, 07:22
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Dear Bernhard,
Can you please explain this a little bit more?
How can I avoid overshooting?
What does fractionExpression has to do with this?
Thank you,
Mojtaba
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   September 2, 2013, 18:19
Assistant Moderator
Bernhard Gschaider
Originally Posted by Mojtaba.a View Post
Dear Bernhard,
Thank you,
Mojtaba
fractionExpression (switching between Neuman and Dirichlet is explained on the groovyBC-page)
The thing is that an infinitely fast heat transfer it is basically a Dirichlet condition. For a "very fast" HT it is something in between a Dirichlet and a Neuman. If you implement a pure Neuman you get the overshoots in this case (just sit down with pen an paper, discretize a boundary cell with a big temperatur difference, a big heat transfer coeff and a big timestep and you'll see the overshoot). You can get rid of this by making the timestep very small or by using a mixed conditon
yanxiang likes this.
Old   October 13, 2013, 05:44
Smile how to implement radiation BC...
Alex
zfaraday will become famous soon enough
where,
Tinf =300K
emissivity=0.775
Thanks in advance.
Hi Mohammad,
Could you, please, help me with the implementation of this boundary condition using groovyBC? I'm new in it and some days ago I was trying to solve a problem where I had to use exactly that BC but I didn't know how to do that using groovyBC. I have been reading and looking for more info about the use of groovyBC but I'm stuck with this problem...
Thanks in advance!
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   October 13, 2013, 21:08
Hi sorry for the late response. For implementing this boundary condition you can do as follows:
type groovyBC;
variables "h=10;k=50;sigma=5.6e-7;E=0.7;Tinf=300;";
gradientExpression "h/k*(T-Tinf)+(sigma/k)*E*(T-Tinf)*(T-Tinf)*(T-Tinf)*(T-Tinf)";
fractionExpression "0";
values are given as dummy. Use your time step smaller. Its works for me.
cheers
Old   October 14, 2013, 08:28
Alex
Thank you Mohammad!
Now I realised that maybe this is not exactly what I was looking for because in my case the radiation heat flux is known. Therefore, maybe i shoud make some change to adapt your boundary conditions to my case.
Anyway, thank you so much! Your help was very useful to me and it helped me to understand a little how groovyBC works! Although I still need to practise quite a lote to learn the power of groovyBC...
Cheers!
Old   October 18, 2013, 01:54
Alexander
sahas is on a distinguished road
Apropos, you can solve the nonlinear equation k*dT/dn = h*(T-Tinf)+(sigma*emissivity)*(T^4-Tinf^4) concerning T by Newton method (few iterations are enough). And for better stability use a relaxation: Tnew=alpha*T+(1-alpha)*Told where alpha < 1. But it is necessary to rewrite k*dT/dn as k/delta*(T-Tinner). I do not know how to find Tinner exactly but something like that can be helpful: Tinner = Twall-snGrad(T)*mag(delta()).
Mojtaba.a likes this.
sahas is offline   Reply With Quote
Old   June 29, 2015, 12:29
Alejandro
ancolli is on a distinguished road
Could you please explain it in a more detailed form? which function I have to use in Newton method? and how can I calculate the derivative of that function?
Thank you
ancolli is offline   Reply With Quote
Old   June 29, 2015, 16:33
Alexander
Thank you
It is simple. The function is:
f(T) = k*dT/dn - h*(T-Tinf)-(sigma*emissivity)*(T^4-Tinf^4)
You should solve the equation:
f(T) = 0.
dT/dn should be rewritten as
k*dT/dn = k/delta*(T-Tinner),
where Tinner = Twall-snGrad(T)*mag(delta()), Twall and snGrad(T) are from previous time step.
You should calculate df/dT:
df/dT = k/delta - h - 4*(sigma*emissivity)*T^3
Please check the signs - I am not sure
Hope this helps you.
Old   June 30, 2015, 11:03
Alejandro
f(T) = 0.
Thank you!
Do you know how to control convergence of BC?. My problem has non-linear bc and takes 200 to 4000 (depending of parameters) iterations (when Newton's method is used). But I do not know how to control the convergence of bc, only modifying simple.correctNonOrthogonal() loop in laplacianFoam by trial and error.
Old   June 30, 2015, 15:15
Alexander
Thank you!
You can make few iterations inside groovyBC. Unfortunately, groovyBC does not support loops (as I know), so you should expand the loop (copy loop body repeatedly)
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 05:41
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Radiation interface hinca CFX 15 January 26, 2014 17:11
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
