Setting BC for a passive scalar (groovy vs fvOptions)
1 Attachment(s)
Hi all,
in the attachement you can se a simple geometry and the value of the passiv scalar I added. For the inlet BC I used groovy in a not very comfortable way :) To get the three seperated inlets I had to build a BC like that: Code:
inlet So the question is, if its possible to do that in a easier way. Maybe with the new fvOptions in 2.2.x like here: http://www.openfoam.org/version2.2.0...processing.php Code:
new scalarTransport - enables the solution of a scalar transport equation, where the scalar can be specified using via boundary conditions, or using the new fvOptions framework. The following images show the time evolution of three point sources added to the pitzDaily tutorial case: Can someone give me an advice or hint, link or something like that? Thanks all Tobi |
