[swak4Foam] Setting BC for a passive scalar (groovy vs fvOptions)
Old   May 23, 2013, 14:53
Default Setting BC for a passive scalar (groovy vs fvOptions)
Tobi's Avatar
Tobias Holzmann
in the attachement you can se a simple geometry and the value of the passiv scalar I added.
For the inlet BC I used groovy in a not very comfortable way
To get the three seperated inlets I had to build a BC like that:
    inlet
        type            groovyBC;
        value           $internalField;
        valueExpression "pos().y>-0.04 ? ( pos().y < -0.035 ? (pos().x<0.002 ? pos().x > -0.002 ? 1 :0 :0 ) : ( pos().y > -0.002 ? pos().y < 0.002 ? (pos().x<0.002 ? pos().x > -0.002 ? 1 :0 :0 ) : (pos().y > 0.035 ? pos().y < 0.04 ? (pos().x<0.002 ? pos().x > -0.002 ? 1 :0 :0 ) : 0: 0) : 0)) : 0";
        valiables       "";
As you can see its a very strange and confusing BC-declaration.
So the question is, if its possible to do that in a easier way.
Maybe with the new fvOptions in 2.2.x like here: http://www.openfoam.org/version2.2.0...processing.php
new scalarTransport - enables the solution of a scalar transport equation,       where the scalar can be specified using via boundary conditions, or using       the new fvOptions framework. The following images show the time       evolution of three point sources added to the pitzDaily tutorial       case:
As I see in the pictures it is possible to set a passive scalar with fvOptions with no additonal work on modifying a solver!
Can someone give me an advice or hint, link or something like that?
Thanks all
Tobi
solving passive scalar by user function in AVLFIRE huyp Main CFD Forum 0 September 4, 2008 10:21
Passive Scalar Andy R FLUENT 0 January 10, 2007 14:49
starwatch & passive scalar isidro Siemens 1 June 24, 2005 23:59
Mixing of a passive scalar Maged Ismail FLUENT 0 June 10, 2005 09:09
Warning 097- AB Siemens 6 November 15, 2004 04:41
