[swak4Foam] have considered using condition in SWAK functions?
Like Tree1Likes
  • 1 Post By gschaider
Old   July 7, 2013, 03:11
Default have considered using condition in SWAK functions?
immortality's Avatar
Ehsan
immortality is on a distinguished road
i want to know applying conditions on time in SWAK function postProcessing is applicable or not?(in one time period have one expression to be calculated and another expression in another time period)
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   July 7, 2013, 10:24
Retired Super Moderator
Bruno Santos
Hi Ehsan,
How about giving an example of what you want to do, already in code?
Best regards,
Bruno
Old   July 20, 2013, 13:11
Ehsan
Hi Bruno
like this:
totalPressure_left
        type swakExpression;
        valueType patch;
        patchName left;
        accumulations (
            average
        variables (
            "gamma1=1.4;"
            "gamma2=1.35;"
            "R=287.14;"
        expression "time()<.002 ? sum(p*(pow(1+(gamma1-1)/2*magSqr(U)/(gamma1*R*T),(gamma1/(gamma1-1))))*rho*area())/sum(rho*area()) : sum(p*(pow(1+(gamma2-1)/2*magSqr(U)/(gamma2*R*T),(gamma2/(gamma2-1))))*rho*area())/sum(rho*area())";
        verbose true;
        outputControlMode outputTime;
        outputInterval 1;
Old   July 21, 2013, 09:16
Bruno Santos
Hi Ehsan,
Sorry, no time to test this myself. My guess is that if you can add 2 fields directly on the resulting expression, then you should be able to use a condition as well.
Best regards,
Bruno
Old   July 22, 2013, 18:18
Assistant Moderator
Bernhard Gschaider
That works. Two things:
- both expression have to give the same result type otherwise the parser will throw up (can't switch from vector to scalar)
- internally BOTH expressions are evaluated, but only the one that fits the condition is used (apart from taking a bit more time this can lead to problems if the expression that is not used with the current condition is mathematically invalid. "log(time()-0.002)" in your example for instance)
Hi Bruno
like this:
totalPressure_left
        valueType patch;
        patchName left;
        accumulations (
            average
        variables (
            "gamma1=1.4;"
            "gamma2=1.35;"
            "R=287.14;"
        verbose true;
        outputInterval 1;
immortality likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Time dependant pressure boundary condition yosuke1984 OpenFOAM Verification & Validation 3 May 6, 2015 06:16
Velocity profile boundary condition Tuca FLOW-3D 1 April 23, 2013 12:02
No-slip condition for non-resolved boundary layer in open channel banks Lupocci Main CFD Forum 1 January 17, 2013 03:11
about the implemention of periodic boundary condition harbinyg Main CFD Forum 5 July 12, 2012 04:30
Boundary condition clarification shaswat CFX 1 April 8, 2012 04:06
