Problem with compiling swak4Foam
1 Attachment(s)
Hey fellow OpenFOAMers,
I'm trying to install the swak4Foam in order to use the groovyBC, however I run into trouble when running the ./Allwmake, the output is really long and appears to have some problems, please find the attachment. I am running OpenFOAM 2.2.1 on Ubuntu 12.04 LTS. I have followed the instructions for swak given at http://openfoamwiki.net/index.php/Contrib/swak4Foam. All help will be appreciated! |
The problem is that the coordSet.H-header moved to a different location in OF2.2. The problem was taken care of on the 9th of March so the fix should be in the releases 0.2.3 and 0.2.4 |
1 Attachment(s)
Thank you Bernhard,
I tried with the 0.2.4 release, but it seems that there still are a few errors with the compilation. |
Greetings to all!
@The_Architect: See this post: http://www.cfd-online.com/Forums/ope...tml#post434217 post #8 edit: I've updated the wiki page about this issue: http://openfoamwiki.net/index.php/Co...am#Downloading Best regards, Bruno |
Thank you Bruno, it works now!
