[swak4Foam] groovybc / swak4foam question
Old   November 18, 2013, 03:24
Default groovybc / swak4foam question
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hi all,
I just implemented a groovybc and I am not sure if I did it right. Can someone confirm that this does what it should? I want the standard "Menter" wall boundary condition for omega:
PIPE_WALL
   type groovyBC;
   valueExpression "10*(6*nu)/(0.075*sqr(y))";
   value uniform 1e9;
How do I know the names of "y" and "nu" for the omega file? Also: Is "y" the denormalized "y+"?
Thanks for any help,
Philipp.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   November 22, 2013, 05:46
Philipp
I'm trying
type groovyBC;
        valueExpression "10*(6*nu)/(0.075*sqr(mag(delta())))";
        value uniform 1e9;
now. Can someone confirm that?
Old   November 22, 2013, 13:13
Assistant Moderator
Bernhard Gschaider
Originally Posted by RodriguezFatz View Post
I'm trying
type groovyBC;
        value uniform 1e9;
No idea. Depends on how this Menter-condition is defined
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 25, 2013, 05:26
Philipp
Boundary condition at the wall (not the first cell point) should be
10 * 6 * viscosity / (0.075 * dy*dy)
with dy = the distance from the wall to the first point.
Old   November 25, 2013, 09:15
Assistant Moderator
Bernhard Gschaider
If with "first point" you mean "cell center" you should be OK: http://openfoamwiki.net/index.php/Co...g_to_need_are:
[swak4Foam] and twoPhaseEulerFoam mnikku OpenFOAM Community Contributions 1 February 19, 2016 05:21
[swak4Foam] Incorrect results of SWAK4FOAM function objects if Parallelisation involved wstapel OpenFOAM Community Contributions 0 December 17, 2015 09:57
[swak4Foam] Varying heat flux using groovyBC with chtMultiRegionSimpleFoam hcl734 OpenFOAM Community Contributions 5 December 15, 2015 08:55
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
[swak4Foam] Wall heat transfer using groovyBC (XiFoam solver) usergk OpenFOAM Community Contributions 7 February 4, 2011 13:36
