[swak4Foam] Unknown function patchAverage in swak4Foam (Control Dict)
Like Tree1Likes
  • 1 Post By gschaider
Old   September 18, 2013, 06:21
Default Unknown function patchAverage in swak4Foam (Control Dict)
franzi_ is on a distinguished road
Hello!
I just wanted to use the function patchAverage in the controlDict, but OpenFOAM tells me, that it doesn't know the type.
I am already using groovyBC, so I assume that swak4Foam is compiled correctly. Than I just added the libs and the functions, but I get this error message.
Hopefully somebody has an idea. Thanks a lot!
Greetings Franzi
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     laplacianFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         2000;
deltaT          0.2;
writeControl    runTime;
writeInterval   20;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
libs ( "libOpenFOAM.so" "libgroovyBC.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" );
functions (
    temp
        type     patchAverage;
        functionObjectLibs
                   "libsimpleFunctionObjects.so"
        verbose     true;
        patches
                   channel
        factor         1;
        fields         ( T );
Error Message:
--> FOAM FATAL ERROR:
Unknown function type patchAverage
Valid functions are :
5
initSwakFunctionObject
patchProbes
probes
sets
surfaces
    From function functionObject::New(const word& name, const Time&, const dictionary&)
    in file db/functionObjects/functionObject/functionObject.C at line 92.
FOAM exiting
franzi_ is offline   Reply With Quote
Old   September 18, 2013, 07:28
Assistant Moderator
Bernhard Gschaider
Originally Posted by franzi_ View Post
Hello!
Greetings Franzi
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
startTime       0;
stopAt          endTime;
endTime         2000;
deltaT          0.2;
writeInterval   20;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
timeFormat      general;
timePrecision   6;
functions (
    temp
        type     patchAverage;
        functionObjectLibs
        verbose     true;
        patches
                   channel
        factor         1;
        fields         ( T );
Error Message:
5
patchProbes
probes
sets
surfaces
FOAM exiting
Hm. Check the output higher up: it should report some problem during the loading of the libraries (the list of FOs should be muuuuch longer). Strange thing is initSwakFunctionObject. That is part of some base library which you don't explicitely specify (although: it could come from groovyBC)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 18, 2013, 08:11
Thank you for the quick reply!! And yes the error message is longer.
I recompiled swak4foam without error message. (just to be sure)
I can see in the error message that OF can't find the libraries, but I don't understand why.
The complete error message is this:
|  \\    /   O peration     | Version:  2.2.x                                 |
Build  : 2.2.x-86ad70d97ea9
Exec   : laplacianFoam
Date   : Sep 18 2013
Time   : 13:46:20
Host   : "sx600.ise.fhg.de"
PID    : 4357
Case   : /scratch/fpfender/OpenFOAM/fkennema-2.2.x/run/NachbauQCAD_TEST
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
--> FOAM Warning :
    From function dlOpen(const fileName&, const bool)
    in file POSIX.C at line 1179
    dlopen error : libsimpleSwakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName&, const bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
    could not load "libsimpleSwakFunctionObjects.so"
--> FOAM Warning :
    dlopen error : libswakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    could not load "libswakFunctionObjects.so"
Create mesh for time = 0
Reading field T
Reading transportProperties
Reading diffusivity DT
SIMPLE: no convergence criteria found. Calculations will run for 2000 steps.
Calculating temperature distribution
--> FOAM Warning :
    dlopen error : libsimpleFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    could not load "libsimpleFunctionObjects.so"
--> FOAM Warning :
    From function dlLibraryTable::open(const dictionary&, const word&, const TablePtr&)
    in file lnInclude/dlLibraryTableTemplates.C at line 67
    Could not open library "libsimpleFunctionObjects.so"
5
patchProbes
probes
sets
surfaces
I don't if maybe the log file of the compilation of swak4foam could be interesting?
Old   September 18, 2013, 17:43
Assistant Moderator
Bernhard Gschaider
Date   : Sep 18 2013
Time   : 13:46:20
PID    : 4357
nProcs : 1
Create time
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Reading field T
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
5
patchProbes
probes
sets
surfaces
If the second compilation went alright there shouldn't be a need. Check whether the libraries are in $FOAM_USER_LIBBIN and also check whether the ".... is up to date" report this location. To be sure try running the removeSwakFilesFromLocal.sh in the maintenance-folder and recompile to be sure
Old   September 19, 2013, 03:55
Oh yes. You are right. The Libraries are missing in the $FOAM_USER_LIBBIN !!!
When I am trying to run the removeFilesfromLocal.sh - it gives following error message - Can't open ./theFiles.sh
just in case- the log file of the swak4foam compilation- it gives some mistake, but I thought it always does that and if it compiles to the end, it is fine.
Old   September 19, 2013, 04:55
Assistant Moderator
Bernhard Gschaider
Usually the best way to spot the errors is to compile a second time. Then only the problematic files pop up in the Log.
Anyway: the problem is that 2.2.x added a new method to the interface of functionObject that the released version of swak4Foam doesn't know about (because it was released before that appeared). This is fixed in the (public) development version of swak4foam
Anne Lincke likes this.
Old   November 27, 2013, 10:30
Default Swak4Foam, libsimpleFunctionObject
Salam Hassan
Salam-H is on a distinguished road
Hi there,
I have the same problem , can you please help me to solve it?
Best regards,
Salam
Salam-H is offline   Reply With Quote
Old   November 27, 2013, 13:38
Assistant Moderator
Bernhard Gschaider
Originally Posted by Salam-H View Post
Hi there,
Best regards,
Salam
It is already described in the previous posting: get the development version as described in http://openfoamwiki.net/index.php/Co...am#Development
Old   November 27, 2013, 14:29
Salam Hassan
Hi ,
Thank you for your reply. I tried to run
hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam openfoam-extend-swak4Foam
it went through without problems. but when i try to up date it with (hg update port_2.0.x)
it says hg update port_2.0.x
abort: no repository found in '/home/salam' (.hg not found)!
any ideas please?
Regards,
salam
Old   November 27, 2013, 17:29
Assistant Moderator
Bernhard Gschaider
Hi ,
any ideas please?
Regards,
salam
Have you changed into the directory you just cloned? (this isn't explicitly stated on the Wiki-page. I assumed that this was clear as it is necessary to compile swak)
Old   November 27, 2013, 17:37
Salam Hassan
Hi ,
No , I haven't changed any thing, and to be honest I don't know what is need to be changed and how to change it. Is there any way that you could direct me please?
Best regards,
Salam
Old   November 28, 2013, 15:27
Assistant Moderator
Bernhard Gschaider
Hi ,
Best regards,
Salam
By "change the directory" I meant use
cd openfoam-extend-swak4Foam
or whatever is the name of the directory you created by cloning. "hg update" will only work in the directory
Old   November 29, 2013, 08:02
Salam Hassan
Thanks for replying, I have updated hg. the problem still there. I think I have installed wrong version of OpenFOAM which may not work with the following swak
svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam
My current version of OpenFOAM is 2.2.2 . Any ideas please?
Regards,
Salam
Old   November 29, 2013, 09:37
Salam Hassan
Regards,
Salam
Just to add some more info:
I checked $FOAM_USER_LIBBIN but I couldn't find libsimpleSwakFunctionObjects.so , do you think this may one of the reasons? if Yes , how do I get the file. I have reinstalled every thing more than 10 times just to make sure that I don't miss any thing, but I never get libsimpleSwakFunctionObjects.so.
Thank you for your help, I can never solve this problem without you help.
Best regards,,
Salam
Old   November 29, 2013, 17:06
Retired Super Moderator
Bruno Santos
Greetings to all!
@Salam: I've consolidated your latest posts into the following thread of yours: http://www.cfd-online.com/Forums/ope...swak4foam.html - I'll be answering there as soon as I can, since it's related to your questions made in the previous posts.
Best regards,
Bruno
Old   November 29, 2013, 17:11
Salam Hassan
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Hi there,
Thank you ever so much for your help. Are you sure you can help me !! I have been spending too much time and energy on this problem,but I cannot solve it. I have been working on it for more than 10 days and still cannot solve it.
I do really thank you for your help .
Best regards,
Salam
Old   December 1, 2013, 06:07
Assistant Moderator
Bernhard Gschaider
This was my first answer on this if I remember it correctly
If you read http://openfoamwiki.net/index.php/Co...am#Downloading closely then you'll see that this is the released version. All my subsequent answers were under the assumption that you used the development version (the one downloaded with mercurial/hg)
I'm sorry for your time. I'd also like to put out a release. But you'll have to understand my problem: I only have a limited time to spend on this kind of community-stuff and all the time that I spend answering further questions from people who didn't properly read the first answer pushes back the next release
Old   December 1, 2013, 13:53
Salam Hassan
Hi there,
Yes you are right, you have been very helpful, I really appreciate your help. I think my problem is almost solved.
Best regards,
Salam
controldict, patchaverage, swak4foam
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 11:59
Control function in Poisson eqtion grid generation? dinhanh Main CFD Forum 0 January 8, 2017 01:53
[swak4Foam] Unknown Function Type "swakExpression" CellZone OpenFOAM Running, Solving & CFD 1 May 3, 2016 07:38
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
