[swak4Foam] Using groovyBC to specify Open boundary conditions |
March 11, 2014, 09:54 |
Olabanji
Hi Foamers,
Please, is it possible to use the groovyBC to specify an open boundary condition. I am trying to simulate a die swell problem and need to specify a traction free surface on the lateral boundaries. Thanks in anticipation. |
March 11, 2014, 16:58 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
You should be a BIT more specific about the mathematical formulation of "traction free", "lateral boundaries" etc. Never expect people to put more time into an answer than you obviously took to formulate the question
March 11, 2014, 17:28 |
#3 | |
Olabanji
Attached is a rough picture of the computational domain and some comments. In particular, what i would like to know is if i can specify the following bc in the attachment with groovybc. 'n' and 'm' denote the unit normal and tangent vectors to the surface and \tau is the total stress tensor. Thanks. |
March 12, 2014, 17:12 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Still the sketch confuses me: are you talking about the boundary condition where you've written "free surface" or of the BC on the free surface between liquid and air (the bulb in your sketch)? Anyway: BC for the stress tensor can usually not be directly enforced but by enforcing a BC on the other fields that ensures that the stress is 0 (something like zeroGradient for U or so)
March 12, 2014, 17:20 |
#5 | |
Olabanji
Is it possible to set a pde as a BC (in cases when it is difficult to obtain analytical solution of the variable on the remote field) and then groovyBC solves for the variable to be used as a BC? |
March 13, 2014, 09:59 |
#6 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I'm not sure what you mean with "set a PDE as a BC". But generally I'd say "no". Usually the BC can be expressed in terms of values and gradients
March 13, 2014, 11:14 |
#7 | |
Olabanji
The flow domain - Inlet and Outlet bc - I had no problem with this one. free surface stress condition - simplified form of the stress condition - Here is a link to the paper . Thanks for the support for the fine utility. Last edited by banji; March 14, 2014 at 19:57. |
March 14, 2014, 19:49 |
#8 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
March 14, 2014, 19:59 |
Olabanji
Thank you!
April 7, 2014, 11:29 |
error when run model with groovyBC
ali
Hi fomers
i want to define U Field and T field in two rooms with BuoyantBoussinesqSimpleFoam solver when immplementation the BC and run model the error into log file has plesae Help me error is : Reading field T --> FOAM Warning : From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(c onst fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict) in file groovyBCFvPatchField.C at line 131 No value defined for T on ceiling therefore using 160{0} Reading field p_rgh --> FOAM Warning : From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(c onst fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict) in file groovyBCFvPatchField.C at line 131 No value defined for p_rgh on ceiling therefore using 160{0} --> FOAM Warning : From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(c onst fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict) in file groovyBCFvPatchField.C at line 131 No value defined for p_rgh on TwallR therefore using 96{0} Reading field U --> FOAM Warning : From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(c onst fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict) in file groovyBCFvPatchField.C at line 131 No value defined for U on ceiling therefore using 160{(0 0 0)} --> FOAM Warning : From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(c onst fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict) in file groovyBCFvPatchField.C at line 131 No value defined for U on TwallR therefore using 96{(0 0 0)} Reading/calculating face flux field phi Selecting incompressible transport model Newtonian |
April 7, 2014, 14:05 |
groovyBC
#11 |
ali
hi fomers
i want to attach file which immplemantaion into groovyBC why error and not to do this model please help me |
April 8, 2014, 11:03 |
#12 | |
Nima Samkhaniani
Rep Power: 24 |
you should add keyword value to your syntax
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
April 8, 2014, 15:06 |
#13 |
ali
thank a lot for note
please let me to check it and tell you if error to be clean |
May 27, 2015, 03:52 |
#14 |
seyyed
Rep Power: 11 |
hi i have same problem what i must do to fix this problem? thanks |
bernhard, groovybc, gschaider, swak4foam |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
