[cfMesh] tichkness Transition top of boundary layer
Like Tree4Likes
  • 1 Post By Fredvol
  • 3 Post By Fredvol
Old   September 17, 2018, 12:18
Default tichkness Transition top of boundary layer
FredPieri
Fredvol is on a distinguished road
Hello ,
Using cfMesh , I wondering how can I smooth the transition in thickness between the top boundary layer cell and the first cell of the mesh ?
I mean it looks like my boundary layer is always one mesh size thick , and it is divide by the number of layer I ask. So teh transistion is size is big.
Please find attach a picture , with 5 and 15 layers. Overall thickness looks the same.
Reading the user Guide I tried to play with the parameters: featureSizeFactor and relThicknessTol . But without sucess.
I found this thread, but it doesn't give me the answer.
boundary layers
What tricks do you use?
Thanks in advance.
Special thanks to franjo_j ans the CfMesh developers.
Fred
ps: Here my boundarylayer MeshDict:
boundaryLayers
//       untangleLayers 0;
    patchBoundaryLayers
        w_wall
            nLayers  1;
            thicknessRation 1.1;
             allowDiscontinuity  1;
     optimiseLayer             1;
    optimisationParameters
        nSmoothNormals             5;
        relThicknessTol         0.15;
        featureSizeFactor         0.4;
        reCalculateNormals         1;
        maxNumIterations         5;
Pavlord likes this.
Fredvol is offline   Reply With Quote
Old   September 17, 2018, 13:19
mzzmrt is on a distinguished road
I guess the source of your problem is a wrong keyword.
Try "thicknessRatio" instead of "thicknessRation"
Then you can play with values...
mzzmrt is offline   Reply With Quote
Old   September 18, 2018, 05:09
FredPieri
Hi mzzmrt
Thanks for your reply and the typo mistake.
unfortunatly , I continue to have a problem.
I think it is geometric problem.
If I use this naming ( see overview.jpg):
The position on each layer can be found using a geometric progression:
https://en.wikipedia.org/wiki/Geometric_progression
I use the mesh ( without BL) size as référence unit.
If I want 10 layers with an expension ratio to 1.2.
the last boudarylayer is only 0.198 thick.
Which make a big gap with the next cell.
If I accept the last boundary cell size to be at least 0.6 thick.
I only have 2 choices:
- nb layer = 101 expension ration = 2.5 !
- expension ratio = 1.2 but only 2 layers.
Please see the other attachement.
am I missing something?
Is there a way to spread more the boundary layer toward the mesh?
Thanks.
Fred
Old   September 18, 2018, 06:22
Well, I am not an expert for the cfMesh and have limited experience with it.
But you can also use the "maxFirstLayerThickness" keyword for declaring it according to your yPlus needs and also try to increase nLayers...
A sample:
w_wall
nLayers 20;
maxFirstLayerThickness 0.002; // use a sutiable size for the geometry here
thicknessRatio 1.2;
Old   September 18, 2018, 08:29
FredPieri
Hi mzzmrt
Thanks again ! Very kind !
Even playing with "maxFirstLayerThickness" I could not get the BL as smmoth as I would like.
I will try more and let this thread knows if I found something.
Cheers
fred
Old   September 24, 2018, 15:54
FredPieri
here an other thread I found having this questions:
2015:
version 1.1 - Total boundary layer thickness
Old   October 18, 2018, 03:57
KHB
lava12005 is on a distinguished road
It seems CFMesh is coded so that the total boundary layer is always around 1 cell height (I hope I am wrong though).
But if the gradient in that area is not high, this should be acceptable I guess?
maxFirstLayerThickness is to set the maximum first layer thickness and it seems it will not give what you want..
lava12005 is offline   Reply With Quote
Old   October 19, 2018, 09:03
FredPieri
Hello Lava12005
Yes I contacted CfMesh on this topic , here their answer:
Thank you for your enquiry. Indeed, smooth transition between boundary layer and inner cells is a feature available only in our commercial meshing software (CF-MESH+).
In general, there is significant difference between capabilities of our commercial (CF-MESH+) and open-source (cfMesh) software packages. Especially when it comes to boundary layers and new functionalities that are being developed (e.g. multi-material meshing, etc.) and to be implemented only in the commercial version. If you wished to try CF-MESH+, please submit your request via: https://cfmesh.com/free-trial/
I hope they will improve the next open-source version of CfMesh.
As it looks very promising, but with this way of doing the boundary layer, I had to swith back to snappyHexMesh.
Regards
fred
Umut, lourencosm and Pavlord like this.
Old   October 21, 2018, 09:22
KHB
Ow, thanks for the information..
Yes CFMesh is a nice tool to have, hope they improve the open-source version..
boundary layer, cfmesh, tickness
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 15:15
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Boundary Layer roughness/ low reynolds wall treatment Luigi_ STAR-CCM+ 1 March 14, 2012 08:40
Boundary Layer Transition Tom A FLUENT 2 January 21, 2012 01:12
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
