problem with Velocity Profile with groovyBC
Iḿ trying to implement a turbulent velocity inlet profile with grooveBC, here is my code Code:
inlet Second error is that if I substitute the variables for their real values I get the following problem: http://i62.tinypic.com/29xdbvo.png As you see it seems like if pos().y is inverted it should be the other way around, not starting from yMax instead starting in y=0 as pos().y<=20*delta0Star says Anyone has a clue about the problem? Thank you very much |
Please: - Use "Save Screenshot" in paraview. So we don't have to look at the Ubuntu-logo - Add a colorbar so that we get a sense of the quantities - Use the "insert Image" of the board. That way the posting gets properly formated. Now it is formatted to the width of your picture which makes it almost unreadable - When talking about values use the cell values not the point-values. Because right now we're looking at interpolation artefacts (in the upper left corner) - to discuss stuff that groovyBC did select only the boundary in question in "Mesh parts" and deselect the internal field. |
