[swak4Foam] MRF vs rotatingWallBC vs funkySetFields
Old   September 7, 2014, 07:18
Default MRF vs rotatingWallBC vs funkySetFields
Nolwenn
Nolwenn is on a distinguished road
Hello everybody,
I try to simulate a rotor and i am very surprised by the results I obtain.
The rotor is rotating at 1.125 rad/s in a flow of 2.25m/s.
I run one case using MRF, here is the fvOptions file
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
MRF1
    type            MRFSource;
    active          true;
    selectionMode   cellZone;
    cellZone         rotationCellZone;
    MRFSourceCoeffs
        origin      (0 0 0);
        axis        (1 0 0);
        omega       -1.125;  //rad/s
I run one case using rotatingWallBC, U is :
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
#include        "include/initialConditions"
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform $flowVelocity;
boundaryField
    //- Set patchGroups for constraint patches
    #include "${WM_PROJECT_DIR}/etc/caseDicts/setConstraintTypes"
    #include "include/lowerAndUpperPatches"
    #include "include/fixedInlet"
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
        value           $internalField;
   "rot.*"
    type rotatingWallVelocity;
    origin (0 0 0);
    axis (1 0 0);
    omega -1.125;  // rad/s
    value uniform (0 0 0);
     fixeGroup
        type            fixedValue;
And one with funkySetField. funkySetBoundaryDict :
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      funkySetBoundaryDict;
velocities1 {
    field U;
    expressions
            target value;
            patchName rot_rotor;
            expression "-1.125*vector(0,-pos().z,pos().y)";
velocities2 {
    field U;
    expressions
            target value;
            patchName rot_blade;
For the 3 cases the BCs on the rotor are correct (see solidBC.jpg)
Mx moment is very small for rotatingWallBC and MRF
Mx moment is very high for funkySet
The velocity around the blades is very different from one case to the other (see rotatingWallBC.jpg, MRFrame.jpg and funkyBC.jpg).
By plotting streams around the rotor I see almost no rotation of the fluid with MRF and rotatingWallBC, and very important rotation with funkyBC.
If someone can help me to understand why my results are so different, it would be very appreciated !
Nolwenn
Nolwenn is offline   Reply With Quote
Old   September 7, 2014, 07:35
Julian Langowski
Ruli is on a distinguished road
Hi Nolwenn,
just a guess: You are comparing absolute and relative velocity fields.
Search the Urel function on this forum and convert absolute intro relative velocity fields an than compare again.
Best regards
Julian
πάντα ῥεῖ - Heraclitus
Ruli is offline   Reply With Quote
Old   September 7, 2014, 09:27
Nolwenn
Hello Julian,
Thanks for your answer, I try to calculate Urel (not working for the moment ...) and I will check this.
Nolwenn
Old   September 7, 2014, 13:31
Nolwenn
Not better ...
Considering Urel or U, the velocity field obtain with MRF is totally different from the one obtain with funkyBC
Old   September 8, 2014, 14:35
Assistant Moderator
Bernhard Gschaider
The sign for omega is correct?
Anyway: why would you not want to use the rotational-BC? It is built for this purpose.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 8, 2014, 15:17
Nolwenn
Hello Bernhard,
Thank you for your answer, the sign of omega is correct (even worst results if I change the sign !).
I tried to use rotational BC (rotatingWallBC) but I am very surprised by the results, the moment around the axis is a lot of smaller than what I expect and the flow around the blades don't seem to rotate (on the picture only the front part and the blades have a rotating BC, the cylinder and the back are fixed).
Nolwenn
Old   September 9, 2014, 10:44
maHein is on a distinguished road
When I do MRF-Simulations, I only use fixedValue boundary conditions since the MRF-Zone already handles the rotational velocity of the walls within the rotating zone (except for those defined as nonRotatingPatches).
maHein is offline   Reply With Quote
Old   September 9, 2014, 14:33
Nolwenn
Hello maHein,
I also use fixedValue boundary conditions when I run MRF simulation. RotatingWallBC is used in another case to compare. But in both cases the resultant moment is to small.
funkysetfields, mrf, rotatingwallbc
MRF and topoSet problem- Rotating volume doesn't rotate andreas0209@hotmail.com OpenFOAM 1 April 4, 2021 13:35
Possibly serious MRF implementation issue Ali Blues OpenFOAM Bugs 1 December 16, 2015 06:04
MRF setup andreas0209@hotmail.com OpenFOAM Pre-Processing 1 August 6, 2015 09:36
Particle tracking in and after MRF andreas0209@hotmail.com OpenFOAM Running, Solving & CFD 1 July 6, 2015 08:36
Should an empty MRF zone really induce this much cross-flow? sylvester OpenFOAM 5 November 18, 2010 03:48
