groovyBC and residualControl
Hi all,
can someone tell me if it is possible to use the groovyBC and change the condition if there is some residualControl criterion reached? Would be very interesting :) If not, is it possible to do that in a easy way. For example:
Thanks in advance Regards Tobi |
Possibility would be to use an appropriate fvOptions-element to get the residual of the matrix, write that to a global variable which the groovyBC could then use. But that fvOptions is yet unwritten. |
Dear Tobi,
I think this can be done using a simple bash script. Do you want to continue solving from the previous results (which has reached the criterion) or start a new case with initial conditions? Both are possible using bash, though. |
Hi, well I solved that problem using groovy but without convergence check... (: using bash script would work too.
