[swak4Foam] groovyBC interFoam splitted inlet -- massflowrate |
September 29, 2014, 12:25 |
#1 | |
Ferdinand Pfender
Rep Power: 12 |
Good evening everyone!
im doing a lot of 2-phase flow calculations in pipes, especially annular-pipes at the moment with differing filling-levels. my standard procedure is to split the inlet into two patches: inlet_liquid and inlet_vapor. Both of these Inlet patches are set up with an own alpha value and with the BC flowRateInletVelocity -- massFlowRate: Actually gmsh is refining very much in lower angles at my inlet-patches (which leads to mesh distortions at the inlet patch). Because of that, im trying to set up a case with only one inlet, which gets divided by groovyBC depending on the filling level of the pipe: Quote:
my problem is the following: im working with high varrying massflowrates (velocities) for both phases. normally im using flowRateInletVelocity -- massFlowRate for both patches/phases, but this is not longer possible because of the usage of groovyBC and one inlet patch. The distribution on one patch via groovyBC results in a not exact distributed area for the inlets and i need to adjust the velocity to get the requested massflowrates. does anybody know how to realize this with groovyBC? how can i get the area values of the distributed inlet patch to recalculate the velocities to get the requested massflowrates? any help is apreciated! thanks a lot! FerdiFuchs Btw: this screenshot is just an example which should clarify my problem. the real inletpatch looks different |
October 1, 2014, 07:51 |
Ferdinand Pfender
Rep Power: 12 |
solved it by using topoSet and createPatch instead of groovyBC.
Like my old method, with 2 patches and massflowrate-inlet. |
setting a Constant Inlet flow - Interfoam | bdh1103 | OpenFOAM Programming & Development | 10 | March 6, 2016 09:29 |
Wave generation inlet using interFoam | Katzenpaul | OpenFOAM Running, Solving & CFD | 2 | February 6, 2013 09:28 |
How to set up the inlet boundary condition for a low pressure case? | beastieboys6 | FLUENT | 3 | April 10, 2012 22:46 |
[swak4Foam] adjust inlet temperature depending on values of monitor points (groovyBC) | braennstroem | OpenFOAM Community Contributions | 2 | May 31, 2011 13:45 |
Inlet diffuser of ramjet | Mohammad Kermani | Main CFD Forum | 25 | December 29, 2000 18:46 |
