fatal error on line 464 of pyFoamApplication.py
Hello, I'm trying to post-process my results using pyFoamSamplePlot. This is what I have:
pyFoamSamplePlot.py --dir=sets ./postProcessing/ --info Code:
pyFoamSamplePlot.py --dir=sets --field=U --time=1 ./postProcessing/ Code:
Error in /home/feba/OpenFOAM/PyFoam-0.6.3/bin/pyFoamSamplePlot.py : FatalError in PyFoam: 'PyFoam FATAL ERROR on line 464 of file /home/feba/OpenFOAM/PyFoam-0.6.3/lib/python2.7/site-packages/PyFoam/Applications/PyFoamApplication.py: No plots produced. Nothing done' in Application-class: SamplePlot The lines 460-464 of that PyFoamApplication.py file read as follows: Code:
def error(self,*args): I'd appreciate your advice! |
The problem seems to be that the utility can't find a line to plot that fits the specification. My first idea would be that the problem is that U is probably a vector. Then it would be a bug. Or the problem is that you specified the postProcessing-directory as the case (try --dir=postProcessing/sets instead). |
Thank you for replying! I have realised that my .xy files are empty... I checked that they were created after running 'sample', but didn't open to see the content. Obviously, it can't see a line to plot, I'm sorry to have wasted your time on that.
However, the issue of 'sample' not sampling over the line persist. I have also tried appending a function in the controlDict file, and it's the same problem - it recognises the function and creates the .xy file, but no data inside (works just fine with point probes though). I've quadruple checked my coordinates, but is the coordinate system perhaps inconsistent with how we define the geometry in blockMeshDict? Any idea what might be causing this? Thanks! |
Anyway: have you checked the coordinates? Maybe the points you specified are outside. One way to check this is open your geometry in Paraview. Create from the "Sources"-menu a "Line". Enter the coordinates you specified and see if the line is where you expect it to be. In fact in the PyFoam-sources in the folder "examples/paraview3" there is a utility that does this for you. But it is unsupported and I haven't used it for some time so I'm not sure whether it works with current PV-versions |
