[PyFoam] having problems with pyfoam Installation |
November 30, 2014, 19:46 |
vitor spadeto
Rep Power: 11 |
I am having problems with pyfoam Installation... after install... I made the test (from http://openfoamwiki.net/index.php/Co...e_installation):
HTML Code:
a@a-Aspire-V3-571:~$ python Python 2.7.3 (default, Feb 27 2014, 19:58:35) [GCC 4.6.3] on linux2 Type "help", "copyright", "credits" or "license" for more information. >>> import PyFoam >>> import PyFoam >>> import PyFoam.FoamInformation >>> print PyFoam.FoamInformation.foamTutorials() >>> Code:
/home/nonroot/OpenFOAM/OpenFOAM-1.2-devel/tutorials my OF: 2.3.0 pyfoam: 0.6.3 I tried to install as root and as regular user... As root: Code:
a@a-Aspire-V3-571:~/PyFoam-0.6.3$ sudo python setup.py install [sudo] password for a: running install running build running build_py running build_scripts running install_lib running install_scripts changing mode of /usr/local/bin/pyFoamReadDictionary.py to 755 changing mode of /usr/local/bin/pyFoamTestConfiguration.py to 755 changing mode of /usr/local/bin/pyFoamSurfacePlot.py to 755 changing mode of /usr/local/bin/pyFoamClearEmptyBoundaries.py to 755 changing mode of /usr/local/bin/pyFoamUpgradeDictionariesTo17.py to 755 changing mode of /usr/local/bin/pyFoamMeshUtilityRunner.py to 755 changing mode of /usr/local/bin/pyFoamRunner.py to 755 changing mode of /usr/local/bin/pyFoamCreateModuleFile.py to 755 changing mode of /usr/local/bin/pyFoamFromTemplate.py to 755 changing mode of /usr/local/bin/pyFoamComparator.py to 755 changing mode of /usr/local/bin/pyFoamDisplayBlockMesh.py to 755 changing mode of /usr/local/bin/pyFoamChangeBoundaryName.py to 755 changing mode of /usr/local/bin/pyFoamNetList.py to 755 changing mode of /usr/local/bin/pyFoamEchoDictionary.py to 755 changing mode of /usr/local/bin/pyFoamTimelinePlot.py to 755 changing mode of /usr/local/bin/pyFoamStandardLogAnalyzer.py to 755 changing mode of /usr/local/bin/pyFoamInitVCSCase.py to 755 changing mode of /usr/local/bin/pyFoamClusterTester.py to 755 changing mode of /usr/local/bin/pyFoamCreateBoundaryPatches.py to 755 changing mode of /usr/local/bin/pyFoamDecompose.py to 755 changing mode of /usr/local/bin/pyFoamExecute.py to 755 changing mode of /usr/local/bin/pyFoamWriteDictionary.py to 755 changing mode of /usr/local/bin/pyFoamUtilityRunner.py to 755 changing mode of /usr/local/bin/pyFoamSamplePlot.py to 755 changing mode of /usr/local/bin/pyFoamEchoPickledApplicationData.py to 755 changing mode of /usr/local/bin/pyFoamCompareDictionary.py to 755 changing mode of /usr/local/bin/pyFoamPrepareCase.py to 755 changing mode of /usr/local/bin/pyFoamVersion.py to 755 changing mode of /usr/local/bin/pyFoamAddEmptyBoundary.py to 755 changing mode of /usr/local/bin/pyFoamCompressCaseFiles.py to 755 changing mode of /usr/local/bin/pyFoamSTLUtility.py to 755 changing mode of /usr/local/bin/pyFoamIPythonNotebook.py to 755 changing mode of /usr/local/bin/pyFoamDumpConfiguration.py to 755 changing mode of /usr/local/bin/pyFoamPlotRunner.py to 755 changing mode of /usr/local/bin/pyFoamPlotWatcher.py to 755 changing mode of /usr/local/bin/pyFoamRedoPlot.py to 755 changing mode of /usr/local/bin/pyFoamPrintData2DStatistics.py to 755 changing mode of /usr/local/bin/pyFoamPVSnapshot.py to 755 changing mode of /usr/local/bin/pyFoamNetShell.py to 755 changing mode of /usr/local/bin/pyFoamPackCase.py to 755 changing mode of /usr/local/bin/pyFoamAddCaseDataToDatabase.py to 755 changing mode of /usr/local/bin/pyFoamPotentialRunner.py to 755 changing mode of /usr/local/bin/pyFoamClearBoundaryValue.py to 755 changing mode of /usr/local/bin/pyFoamUpgradeDictionariesTo20.py to 755 changing mode of /usr/local/bin/pyFoamCaseBuilder.py to 755 changing mode of /usr/local/bin/pyFoamChangeBoundaryType.py to 755 changing mode of /usr/local/bin/pyFoamRunAtMultipleTimes.py to 755 changing mode of /usr/local/bin/pyFoamSGECommand.py to 755 changing mode of /usr/local/bin/pyFoamClearInternalField.py to 755 changing mode of /usr/local/bin/pyFoamCaseReport.py to 755 changing mode of /usr/local/bin/pyFoamListCases.py to 755 changing mode of /usr/local/bin/pyFoamAPoMaFoXiiQt.py to 755 changing mode of /usr/local/bin/pyFoamUpdateDictionary.py to 755 changing mode of /usr/local/bin/pyFoamJoinCSV.py to 755 changing mode of /usr/local/bin/pyFoamBench.py to 755 changing mode of /usr/local/bin/pyFoamConvertToCSV.py to 755 changing mode of /usr/local/bin/pyFoamSymlinkToFile.py to 755 changing mode of /usr/local/bin/pyFoamSteadyRunner.py to 755 changing mode of /usr/local/bin/pyFoamClearCase.py to 755 changing mode of /usr/local/bin/pyFoamDumpRunDatabaseToCSV.py to 755 changing mode of /usr/local/bin/pyFoamMetaServer.py to 755 changing mode of /usr/local/bin/pyFoamPVLoadState.py to 755 changing mode of /usr/local/bin/pyFoamCloneCase.py to 755 changing mode of /usr/local/bin/pyFoamBuildHelper.py to 755 changing mode of /usr/local/bin/pyFoamModifyGGIBoundary.py to 755 changing mode of /usr/local/bin/pyFoamCopyLastToFirst.py to 755 running install_egg_info Removing /usr/local/lib/python2.7/dist-packages/PyFoam-0.6.3.egg-info Writing /usr/local/lib/python2.7/dist-packages/PyFoam-0.6.3.egg-info a@a-Aspire-V3-571:~/PyFoam-0.6.3$ |
December 1, 2014, 12:04 |
#2 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
December 2, 2014, 05:44 |
vitor spadeto
Rep Power: 11 |
" thank you for attention friend. "Is the FOAM_TUTORIALS-variable set on that shell?" Im sorry... I am a beginner.. can you tell me how to do it?
and results of pyFoamVersion.py are: Code:
a@a-Aspire-V3-571:~$ pyFoamVersion.py Machine info: Linux | a-Aspire-V3-571 | 3.11.0-26-generic | #45~precise1-Ubuntu SMP Tue Jul 15 04:02:35 UTC 2014 | x86_64 | x86_64 Python version: 2.7.3 (default, Feb 27 2014, 19:58:35) [GCC 4.6.3] Python executable: /usr/bin/python PYTHONPATH is not set Location of this utility: /usr/local/bin/pyFoamVersion.py PyFoam WARNING on line 192 of file /usr/local/lib/python2.7/dist-packages/PyFoam/FoamInformation.py : Basedir /home/a/OpenFOAM for fork openfoam does not exist or is not a directory Version () Fork openfoam of the installed 1 versions: extend-3.1 : /home/a/foam/foam-extend-3.1 This version of OpenFOAM uses the old calling convention pyFoam-Version: 0.6.4 ALERT: Reported version (0, 6, 4) is different from hardcoded version (0, 6, 3) -> probably inconsistent library installation Path where PyFoam was found (PyFoam.__path__) is ['/usr/local/lib/python2.7/dist-packages/PyFoam'] Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/a/.pyFoam/pyfoamrc'), ('directory', '/home/a/.pyFoam/pyfoamrc.d')] Configuration files (used): [] Installed libraries: cython : No Not used. Maybe will by used later to spped up parts of PyFoam cProfile : Yes docutils : No Not necessary. Needed for RestructuredText to HTML conversion Gnuplot : No Not a problem. Version from ThirdParty is used hotshot : Yes ipdb : No Not necessary. Only makes debugging more comfortable IPython : No Not necessary. But the interactive shell may be more comfortable matplotlib : No Only Gnuplot-plotting possible mercurial : Yes version: 2.0.2 nose : No Only needed for running the unit-tests (developers only) Numeric : No Not supported anymore. No need to install it numpy : Yes version: 1.6.1 openpyxl : No Not a problem. Only used for exporting pandas-data to Excel-files (advanced) pandas : No Not a problem. Only used for handling of advanced data-handling ply : No Not a problem. Version from ThirdParty is used profile : Yes psyco : No Not a problem. Acceleration not possible PyQt4 : Yes version: 4.8.1 PyQt4.Qwt5 : No Only an alternate plotting back-end scipy : No Not yet used. Possibly use signal-fitting etc Tkinter : No Not a problem. Used for the old version of DisplayBlockmesh and some matplotlib-implementations twisted : Yes version: 11.1.0 vtk : Yes version: 5.8.0 xlwt : No Not a problem. Only used for exporting pandas-data to Excel-files Library locations cProfile : /usr/lib/python2.7/cProfile.pyc hotshot : /usr/lib/python2.7/hotshot/__init__.pyc mercurial : /usr/lib/python2.7/dist-packages/mercurial/__init__.pyc numpy : /usr/lib/python2.7/dist-packages/numpy/__init__.pyc profile : /usr/lib/python2.7/profile.pyc PyQt4 : /usr/lib/python2.7/dist-packages/PyQt4/__init__.pyc twisted : /usr/lib/python2.7/dist-packages/twisted/__init__.pyc vtk : /usr/lib/pymodules/python2.7/vtk/__init__.pyc a@a-Aspire-V3-571:~$ |
December 2, 2014, 07:18 |
#4 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
[PyFoam] Problems with installing PyFoam | Christoph_84 | OpenFOAM Community Contributions | 34 | October 26, 2021 11:25 |
[PyFoam] unknown or ambiguous terminal type x11 | Tobi | OpenFOAM Community Contributions | 6 | August 13, 2020 11:09 |
Problems installing SVN in Ubuntu (for later installing PyFoam for OpenFOAM) | immortality | Lounge | 2 | May 24, 2014 03:05 |
Problems with installation | batta31 | OpenFOAM Installation | 2 | September 4, 2012 07:01 |
installation problems on upgrade from win 3.26 to | mic | Siemens | 5 | June 20, 2007 09:40 |
