December 3, 2014, 14:36 |
on run time object
Hao Chen
I want to extract the sum of a vector field in a cell zone at every time step. The cell zone is already set up in the mesh. The vector field is something like: (a & U + mag(U) * b & U) * cellVolume where a and b are 3*3 tensor and & means the inner product. So the final result is supposed to be a vector. It seems that swak4foam can do that but I never use it before. I am trying to find some information and any helps are appreciated! Best regards Hao |
December 3, 2014, 16:55 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The basic training from the 9th Workshop is probably currently the best introduction (and it even has an example with a cellset if I remember it correctly)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
December 4, 2014, 05:40 |
#3 | |
Hao Chen
Hi Bernhard:
Thanks for your information. So swak4foam can do that right? I am trying to learn it and also pyFoam. When I install Pyfoam and use pyFoamPlotRunner, it shows some error so it did not plot the residuals: Code:
gnuplot> set terminal x11 ^ line 0: unknown or ambiguous terminal type; type just 'set terminal' for a list gnuplot> set terminal x11 gnuplot> set terminal x11 noraise ^ ^ line 0: line 0: unknown or ambiguous terminal type; type just 'set terminal' for a list unknown or ambiguous terminal type; type just 'set terminal' for a list gnuplot> set terminal x11 noraise ^ line 0: unknown or ambiguous terminal type; type just 'set terminal' for a list gnuplot> set terminal x11 ^ line 0: unknown or ambiguous terminal type; type just 'set terminal' for a list gnuplot> set terminal x11 noraise ^ line 0: unknown or ambiguous terminal type; type just 'set terminal' for a list PyFoam WARNING on line 142 of file /usr/local/lib/python2.7/dist-packages/PyFoam/LogAnalysis/GeneralLineAnalyzer.py : Problem doing timelines could not convert string to float: PyFoam WARNING on line 142 of file /usr/local/lib/python2.7/dist-packages/PyFoam/LogAnalysis/GeneralLineAnalyzer.py : Problem doing timelines could not convert string to float: PyFoam WARNING on line 142 of file /usr/local/lib/python2.7/dist-packages/PyFoam/LogAnalysis/GeneralLineAnalyzer.py : Problem doing timelines could not convert string to float: Code:
Python version: 2.7.6 (default, Mar 22 2014, 22:59:56) [GCC 4.8.2] Python executable: /usr/bin/python Python 2.7 is one development platform for PyFoam (along with Python 3) PYTHONPATH is not set Location of this utility: /usr/local/bin/pyFoamVersion.py PyFoam WARNING on line 192 of file /usr/local/lib/python2.7/dist-packages/PyFoam/FoamInformation.py : Basedir /home/hchen/OpenFOAM for fork openfoam does not exist or is not a directory Version 3.1 Fork extend of the installed 1 versions: extend-3.1 : /home/hchen/foam/foam-extend-3.1 pyFoam-Version: 0.6.4 Path where PyFoam was found (PyFoam.__path__) is ['/usr/local/lib/python2.7/dist-packages/PyFoam'] Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/hchen/.pyFoam/pyfoamrc'), ('directory', '/home/hchen/.pyFoam/pyfoamrc.d')] Configuration files (used): [] Installed libraries: cython : No Not used. Maybe will by used later to spped up parts of PyFoam cProfile : Yes docutils : No Not necessary. Needed for RestructuredText to HTML conversion Gnuplot : No Not a problem. Version from ThirdParty is used hotshot : Yes ipdb : No Not necessary. Only makes debugging more comfortable IPython : No Not necessary. But the interactive shell may be more comfortable matplotlib : Yes version: 1.3.1 mercurial : Yes version: 2.8.2 nose : No Only needed for running the unit-tests (developers only) numpy : Yes version: 1.8.2 openpyxl : No Not a problem. Only used for exporting pandas-data to Excel-files (advanced) pandas : No Not a problem. Only used for handling of advanced data-handling ply : No Not a problem. Version from ThirdParty is used profile : Yes psyco : No Not a problem. Acceleration not possible PyQt4 : Yes version: 4.8.6 PyQt4.Qwt5 : No Only an alternate plotting back-end scipy : Yes version: 0.13.3 Tkinter : Yes version: $Revision: 81008 $ twisted : Yes version: 13.2.0 vtk : Yes version: 5.8.0 xlwt : No Not a problem. Only used for exporting pandas-data to Excel-files xlrd : No Not a problem. Only used for importing Excel-files to pandas-data Library locations cProfile : /usr/lib/python2.7/cProfile.py hotshot : /usr/lib/python2.7/hotshot/__init__.py matplotlib : /usr/lib/pymodules/python2.7/matplotlib/__init__.pyc mercurial : /usr/lib/python2.7/dist-packages/mercurial/__init__.pyc numpy : /usr/lib/python2.7/dist-packages/numpy/__init__.pyc profile : /usr/lib/python2.7/profile.py PyQt4 : /usr/lib/python2.7/dist-packages/PyQt4/__init__.pyc scipy : /usr/lib/python2.7/dist-packages/scipy/__init__.pyc Tkinter : /usr/lib/python2.7/lib-tk/Tkinter.py twisted : /usr/lib/python2.7/dist-packages/twisted/__init__.pyc vtk : /usr/lib/pymodules/python2.7/vtk/__init__.pyc Checking additional envirnoment variables Checking for PYFOAM_DIR : Location of the PyFoam-installation. Not strictly necessary PYFOAM_DIR missing from environment Checking for PYFOAM_SITE_DIR : Location of non-PyFoam-disctributions script. Set and used by some Foam-distributions PYFOAM_SITE_DIR missing from environment Can you figure out the reason? Best regards Hao Quote:
December 4, 2014, 09:06 |
Hao Chen
I solved the problem, it is just because of the version of Gnuplot. I reinstall gnuplot-x11 and seems solved.
But it is a bit wired since it shows that it uses the third party of pyfoam so the gnuplot version should be correct... Best regards Hao |
December 4, 2014, 09:25 |
#5 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
pyFoam can only check for the existence of the Gnuplot-Python-library. It COULD check for the gnuplot-binary but checking whether the binary supports the x11-terminal would be harder
December 4, 2014, 10:57 |
#6 | |
Hao Chen
Hi Bernhard:
I went through some of the presentations you gave in the workshop and thanks very much that you develop this wonderful utility! For my case I can add these in the controlDict: Code:
functions ( whichFields { type listRegisteredObjects; outputControlMode startup; } volumeForceSum { type swakExpression; valueType cellZone; zoneName in; accumulations (sum); expression "vol()*U+mag(U)*vol()*U"; verbose true; outputControlMode timeStep; outputInterval 1; } ); libs ( "libOpenFOAM.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libgroovyBC.so" ); Best regards Hao Quote:
December 4, 2014, 15:39 |
#7 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Transient run continues from last time (when startover is desired) | bongbang | CFX | 2 | March 22, 2015 23:05 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
