[PyFoam] Using pyFoam to extract BCs from text file and automate my own solver
Like Tree2Likes
  • 2 Post By gschaider
Old   December 3, 2014, 07:03
Post Using pyFoam to extract BCs from text file and automate my own solver
Edward Shorthouse
e.shorthouse is on a distinguished road
Hello all,
I have a text file with 40 sets of boundary conditions (4 parameters in each BC set).
I'm trying to use pyFoam to extract one BC set at a time and feed into my case, and to run my own solver on that case (a variant of buoyantBoussinesqSimpleFoam). Q: Do I need a separate text file for each boundary condition, or can pyFoam extract the values for each of the 40 BC parameters from a single text file?
Once each case has converged I want to take the BCs from the last time step of that case and use as the first time step for the next case.
Can all the above be done using one pyFoam utility? If so, which one is most appropriate.
Thanks!
Last edited by e.shorthouse; December 3, 2014 at 07:04. Reason: format of table looked wrong
e.shorthouse is offline   Reply With Quote
Old   December 3, 2014, 08:44
Assistant Moderator
Bernhard Gschaider
Originally Posted by e.shorthouse View Post
Hello all,
Thanks!
I'm not quite clear what you mean with "extract one BC set at a time". Is this "set by the user" or "set as the result of a solver run". Also: please stay with the OF-nomenclature "BC set" means what? A patch? Or a boundary field on a patch? I think it would be best if you explained in a step by step fashion what you're currently doing. Then I can give you a concrete answer. Currently I can think of at least 4 different ones depending on what you mean
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 3, 2014, 09:47
Edward Shorthouse
Thanks Bernhard, by BC I mean boundary conditions for my 0 time directory. All the boundary conditions are set by me (the user) which are in a separate text file.
The 4 user variables (in addition to the standard ones 'k', 'epsilon' etc which are kept the same for each case) used in the boundary conditions are: wall surface temp, floor surface temp, relative humidity and air speed. I have 40 sets of values for these variables which I want to run on my case. I've attached the text file with the user variables.
I am running my solver on the same mesh using the 40 different user set boundary conditions (so I have 40 cases because the boundary conditions are different every time). This is what I want to automate with pyFoam.
Running 40 cases in series will take a long time, so to speed up convergence for each case, I want to use the latestTime directory from the previous converged case to start off my run for the next case.
Hope that makes sense,
Thanks
File Type: xls Training Data for OpenFoam Building Model - 251114.xls (13.0 KB, 9 views)
Old   December 3, 2014, 10:22
Assistant Moderator
Bernhard Gschaider
Thanks
You want to do a "parameter variation". Since the release last week there is a utility pyFoamRunParameterVariation.py which builds on the template engine described here http://openfoamwiki.net/staticPages/....slides.html#/
Two problems with that:
- apart from the online-help there is no documentation on this
- it varies the 4 parameters independently and judging from that you have 40 sets this is not applicable for your case
Apart from that I think you'll have to write a script yourself. Something like http://openfoamwiki.net/index.php/Co...eter_Variation
The main "challenge" would be getting the values into the script but the DictReader from https://docs.python.org/2/library/csv.html might be your friend here
davibarreira and e.shorthouse like this.
pyfoam
Using fluent loop to automate write to the file Eman. FLUENT 1 November 17, 2017 03:02
Hybrid discretisation - blend factor gcoopermax CFX 5 September 23, 2016 08:05
Flow 3D Cast Exporting Output as Text File shantanu1 FLOW-3D 0 October 30, 2015 11:51
Journal file to automate a time step change Damien_CFD FLUENT 0 August 2, 2011 07:05
