[openSmoke] Pathing error in solver installation "radiationOpenSMOKE++"
Old   September 10, 2019, 14:00
Post Pathing error in solver installation "radiationOpenSMOKE++"
Hafiz Ahmad
mdhfiz is on a distinguished road
I have been trying to compile a solver for quite some time now. when I compile the solver, I get this error:
unknown option: '-I../../libs/radiationOpenSMOKE++/lnInclude'
Due of this the compilation failed. I have read the user guide of OF6 and understand that the path for the dependencies are listed under options. Somehow, in that folder, the "unknown option" was listed correctly (to my knowledge):
-I../../libs/radiationOpenSMOKE++/lnInclude \
This is the next 2 lines after I enter in wmake:
wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries:
Side Note
radiationOpenSMOKE++ was successfully compiled (No error messages and as far as I know, no missing dependencies). radiationOpenSMOKE++ is part of libs folder and is needed to compile the solvers.
Because of this failure of recognizing this directory, the more following dependency files failed to be opened. Could somebody point out where I might go wrong?
mdhfiz is offline   Reply With Quote
Old   February 29, 2020, 11:15
Default Did you fix the problem?
Gontzal
GL94 is on a distinguished road
Hi Hafiz, im having the same problem. Did you fix the error? Can you tell me how?
Regards
GL94 is offline   Reply With Quote
Old   March 2, 2020, 02:36
Hafiz Ahmad
There was no error at the first place. You can test it by running the test case.
Population Balance Modeling (PBM) - Ansys Fluent chittipo FLUENT 164 November 18, 2023 11:54
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 15:44
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 05:21
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 16:25
