[cfMesh] mesh improvements for 'face tets'
Old   September 1, 2015, 13:15
Default mesh improvements for 'face tets'
pici's Avatar
Pierluigi Cirrottola
pici is on a distinguished road
Hi to everybody.
I'm using cfMesh to create meshes for complicated body.
It works well, but too much often I find 'face tet' errors; using simpleFoam or pimpleFoam it is only a warning (openFoam doesn't stop), but using Particle Tracking solver (e.g. DMPFoam or icoUncoupledKinematcParcelFoam) it becomes a blocking error.
Using "checkMesh -allGeometry" I should find 'face tet' errors: but cfMesh version and openFoam official version give different results: attached you will find two logfile that use the same mesh, generated by cfMesh.
They are really different, and it seams that cfMesh version is incomplete.
But the true question is: how can I improve the mesh quality in cfMesh, other then using improveMeshQuality tool? and how could I set its optional parameter?
Thank you a lot
Piero
pici is offline   Reply With Quote
Old   September 2, 2015, 04:31
Franjo Juretic
franjo_j is on a distinguished road
Send a message via Skype™ to franjo_j
The installation of cfMesh is compiled with foam-extend-3.1, and the checkMesh uses standard mesh checks implemented in foam-extend-3.1. You are using OpenFOAM-2.4.0 for your simulation, and it has some additional checks implemented there.
To improve the quality inside cfMesh, you need to check whether the checks of your interest are already implemented there, and use them in the optimisation process. It is not available via some settings, you need to do some programming.
Regards,
Franjo
Principal Developer of cfMesh and CF-MESH+
www.cfmesh.com
Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram
franjo_j is offline   Reply With Quote
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 13:28
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
