[swak4Foam] Installation of swak4Foam for openfoam 1.6.x
Old   October 22, 2015, 09:00
Default Installation of swak4Foam for openfoam 1.6.x
as
anuja is on a distinguished road
Hello ,
I am facing problems with the swak4Foam installation. I have attached the make.log file. Can you please help?
thats what the make.log file says -->
Previously compiled for OpenFOAM 1.6
Reading variables from 'swakConfiguration'
swakConfiguration: line 1: python-config: command not found
swakConfiguration: line 2: python-config: command not found
swakConfiguration: line 13: [: : integer expression expected
Checking swak4Foam-version and generating file
Swak version is 0.3.2
Bison is version 2.7
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 1 Minor 6 Patch 1.6 (1.6)
No change to swak4FoamParsers/foamVersion4swak.H
SOURCE=entryToExpression/entryToExpression.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/sampling/lnInclude -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/triSurface/lnInclude -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/surfMesh/lnInclude -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/lagrangian/basic/lnInclude -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/entryToExpression.o
entryToExpression/entryToExpression.C: In static member function ‘static Foam::autoPtr<Foam::entryToExpression> Foam::entryToExpression::New(const Foam::word&)’:
entryToExpression/entryToExpression.C:72: error: ‘class Foam::HashTable<Foam::autoPtr<Foam::entryToExpress ion> (*)(), Foam::word, Foam::string::hash>’ has no member named ‘sortedToc’
make: *** [Make/linux64GccDPOpt/entryToExpression.o] Fehler 1
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard
Thanks in advance!
File Type: gz make.log.tar.gz (45 Bytes, 1 views)
anuja is offline   Reply With Quote
Old   October 22, 2015, 10:18
Default Installation of smak4Foam for openfoam 1.6x
as
I am trying to install swak4Foam for Openfoam 1.6 version. But I am facing certain errors. Can someone please help me as I am in need of FunkySetFields for my master project. I have attached the log file below.
Thanks a lot!
Old   October 22, 2015, 16:20
Bruno Santos
wyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of light
Quick questions:
  1. Are you 100% certain that you are using OpenFOAM 1.6.x? Because the output messages all indicate that you have OpenFOAM 1.6 installed.
  2. In addition, what installation instructions did you follow?
  3. And why are you trying to use OpenFOAM 1.6?
Old   October 23, 2015, 06:47
as
I have installted Openfoam 1.6. I want to install FunkySetfields that is why i am using version 1.6.
I used the isntructions from the openfoamwiki site.
Old   October 24, 2015, 13:07
Bruno Santos
Greetings anuja,
If you are using version 1.6 because of the instructions on this page: https://openfoamwiki.net/index.php/C...funkySetFields
then please see that it says there that:
Note: Active development of funkySetFields now takes place in swak4Foam so please have a look there for more up-to-date versions. Support for this version of funkySetFields is discontinued with OpenFOAM 2.0.
This means that funkySetFields is part of the swak4Foam toolkit. It's only the independent version that has been discontinued.
If you can, please install a more recent version of OpenFOAM and install swak4Foam.
But only if you must use OpenFOAM 1.6, then I'll try to take a look into this.
Best regards,
Bruno
Thread Tools
Trackbacks are On
[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM steven123 OpenFOAM Community Contributions 30 September 21, 2017 16:00
[swak4Foam] [OpenFOAM plus] [v1612+] swak4Foam installation problem in Windows (Allwmake) LThomes OpenFOAM Community Contributions 6 May 27, 2017 06:53
[swak4Foam] swak4Foam 0.3.1 OF2.2.2 Installation Issue scnsc OpenFOAM Community Contributions 3 August 20, 2014 07:59
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
[swak4Foam] About installation of swak4Foam mmkr825 OpenFOAM Community Contributions 10 December 14, 2012 02:24
