overlapping problem using cfMesh v1.1.1
Hi to everybody,
I'm using a.s.a.p cfMesh (instead of snappyHexMesh), because it is infinitely more friendly then oF. But, when I must import CAD geometry (for complex parts), some time I receive this error message, when I check trisurface .fms mesh, using checkSurfaceMesh utility. Code:
Found overlapping parts in the surface mesh!! - I import a step file in Salomé (rel 7.6.0) - I create an opportune set of face groups and, using extractFeatureEdges.py, also the FeatureEdge group - I create a 2D mesh (only on surfaces) ad I add elements group by geometry - finally, I export the just created mesh in .fms file, using salomeTriSurf.py utility. Before to start final meshing process, I check this trimesh using checkSurfaceMesh and very often I receive the message already reported. It never happens when I create geometry directly in Salomé. My question is: how can I see where is the overlapping? is it possible to have a list of overlapped faces? This kind of informations could be very useful to correct the initial step file (because I'm almost sure that the the problem is there :cool:). Thank you in advance __________ Piero |
Regards, Franjo |
Hi Franjo,
thank you very much for your fast reply. These overlapped faces, are they doubled? is it possible to delete them (e.g. deleting triangles in stl file)? Thank you in advance. Best regards __________Piero |
