and twoPhaseEulerFoam
I have been trying to do some circulating fluidized bed simulations with twoPhaseEulerFoam and utilizing groovyBC for circulation of the elutriated particles back to the system. I am using openFoam-3.0.1 and swak4foam-0.4.0 (managed to get it working with these instructions). I've had a lot of problems with mass (or energy) conservation (probably more on these issues on other posts after this test) and I am currently trying to eliminate possible sources of errors, one of which could be the particle circulation code. The swak4foam code was taken from here but I was recently told that twoPhaseEulerFoam solver uses alphaRhoPhi-variables (1 and 2) for mass flow of both phases (twoPhaseEulerFoam/createFields.H). The problem is that I cannot/don't konw how to use this variable directly for swak4foam. I have tried variables Code:
PIMPLE: iteration 1 This leaves me with several questions: 1) What variables can swak4foam get from a solver? Are they predefined somehow somewhere or do they need to be saved to a file? 2) How to successfully implement this kind of circulation code? It was also suggested that this circulation could be done with a custom boundary condition, but I would rather utilize this simpler and (to me) less complex method. Thanks in advance! |
So the correct answer to this issue was "alphaRhoPhi.particles" which is quite logical, silly me... :rolleyes:
Way to confirm this was by adding this to the "controlDict" under "functions": Code:
whichFields { So, lets see if this remedies the mass conservation issues. |
