[ImmersedBoundary] Error while running IBM solver |
February 22, 2016, 21:27 |
Pavan
Rep Power: 10 |
I downloaded the IBM solvers and turtorials from openfoamwiki.
I am encountering the following error, while running my case --> FOAM FATAL ERROR: allPoints.size() < 9 : 7 From function void immersedBoundaryFvPatch::makeInvDirichletMatrices( ) in file immersedBoundaryFvPatch/immersedBoundaryFvPatchLeastSquaresFit.C at line 91. FOAM aborting I looked into the source code in immersedBoundaryFvPatchLeastSquaresFit.C line 91. I understand that the allpoints.size() should be grater than ncoeffs for the case to run. But I am having a hard time following the lineage to the definition of these variables. Can somebody help. Last edited by pvpnrao; February 22, 2016 at 22:51. |
April 16, 2016, 12:07 |
K.H
Rep Power: 10 |
i am having the same problem. did you manage to fix it somehowe??
April 16, 2016, 13:30 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick questions:
April 16, 2016, 23:37 |
Pavan
Rep Power: 10 |
Wyldckat
I used the instructions given on the following webpage https://openfoamwiki.net/index.php/E...mersedBoundary I am using Foam Extend 3.1. Foam 3.2 was not yet released when I started working with IBM. Although, I did not try attempting to fix this issue yet. But, from my correspondence with Prof. Jasak, I understand, this is a mesh refinement problem, the immersed boundary is not being able to find a cell centroid for interpolation. So, if I keep refining the mesh locally using cellSet+RefineMesh do you think I should be able to fix the problem. |
April 17, 2016, 10:48 |
K.H
Rep Power: 10 |
I don't think refining the mesh is the solution cause my case with a complex Ib runs perfectly on a coarse grid. The mentioned error only occurs after refining the mesh
April 17, 2016, 17:54 |
Bruno Santos
Rep Power: 128 |
Quick answer: The best I can do on this topic is to suggest that you build from source code the "nextRelease" branch from foam-extend 3.2. It has several updates to IBM, including some related to dynamic meshing.
To get the correct branch, either clone directly: Code:
git clone --branch nextRelease git://git.code.sf.net/p/foam-extend/foam-extend-3.2 Code:
git checkout nextRelease |
April 19, 2016, 10:46 |
K.H
Rep Power: 10 |
Wyldckat
I now use foam-extend 3.2 but still get the same error. Any other suggestions? |
April 20, 2016, 04:17 |
#9 |
K.H
Rep Power: 10 |
I'm running a case of turbulent channel flow where the IB consisting of a smooth plate represents the walls of the channel. this case is running well until i exchange the smooth plate IB with a complex structured IB. the new case is only running for a coarse grid. when i refine the mesh I'm getting the mentioned error. What further informations do you need?
I could send you the case then you could reproduce the error usingt the icoIbFoam solver though I'm using a modified version |
April 20, 2016, 17:47 |
#10 |
Bruno Santos
Rep Power: 128 |
Sorry, I should have pointed out that you should have followed the instructions on this thread: http://www.cfd-online.com/Forums/ope...-get-help.html
The idea is that without a test case, I can't reproduce the same error you're getting. I could very easily spend 2h trying to try and reproduce the same error you're getting and always not get an error message . edit: At the very least, I need detailed instructions on how to use an existing tutorial case and configure it to give the same crash you are getting. Last edited by wyldckat; April 20, 2016 at 17:48. Reason: see "edit:" |
April 21, 2016, 03:06 |
icoIbFoam channel flow with komplex IB, --> FOAM FATAL ERROR: allPoints.size() < 9
#11 |
K.H
Rep Power: 10 |
I modified the channelFoam tutorial to run the case with icoIbFoam-solver and a complex IB as channel walls. A sketch of the geometry can be found under the link:https://www.dropbox.com/s/euwbfw0b05...leyIB.jpg?dl=0
and a screendump of the mesh under the link:https://www.dropbox.com/s/nvbpnj04n7t29li/mesh.jpg?dl=0 The output of checkmesh can be found under the link: https://www.dropbox.com/s/smhvofhqnz...kMesh.log?dl=0 Link to fvSchemes: https://www.dropbox.com/s/ciaumy6j2h...fvSchemes?dl=0 Link to fvSolution: https://www.dropbox.com/s/a7z956vzm0...vSolution?dl=0 The output of the terminal is: https://www.dropbox.com/s/3nneljz2j5...bFoam.log?dl=0 And a link to the full case: https://www.dropbox.com/sh/d5bw0xi8l...eVZJILh1a?dl=0 note that if I reduce the mesh resulotion to the half and again add the IB-statement in the boundary file the case runs without the mentioned error |
May 1, 2016, 19:34 |
#12 |
Bruno Santos
Rep Power: 128 |
@urion - Quick answer: I only managed to take a quick look into this the other day and I haven't managed to do any tests yet.
What comes to mind is that the problem might be related to the fact that your STL files are on the borders of the mesh, which might be the reason for this problem. At least if I understood you correctly, the problem also occurs when the whole mesh is refined, which could lead to numerical issues. Which reminds me: please try increasing the refinement in the STL files as well. For example, in ParaView you can use the filter "Subdivide", which will divide each triangle on the STL into several smaller triangles. This might help with numerical issues, because each point on the mesh will be able to better "see" the nearby vertices of the triangles, therefore leading to smaller numerical errors... at least in theory. |
May 2, 2016, 02:25 |
prevent pressure correction in IB
#13 |
K.H
Rep Power: 10 |
hi wyldckat thanks for your answer. i will try refining the stl-file as well. I have another question regarding the solver I am using. I expanded the icoIbFoam solver in foam extend 3.1 by the prssure-correction made in the solver channelFoam so i can use the new solver as DNS-solver for turbulent channel flow with IB. The problem is that the pressure correction seems to be performed in the whole channel but i dont want to perform the pressure correction in the IB. what changes do i have to make to the solver especially the pressure correction to prevent this.?
Link to used solver: https://www.dropbox.com/sh/wfgf194ul...u3_FkDEAa?dl=0 |
December 6, 2016, 04:35 |
#14 |
Dong Zhang
you can try to exame your surface normals in your stl file, the surface normals of all the triangles should point outward.
June 25, 2017, 19:57 |
#15 |
Chung Shen
Dear All,
I installed foam-extend-4.0 on Ubuntu 16.04 and tried to run the tutorial movingCynlinderInChannelIco in parallel with 8 processors. The only thing I modified is, in system/decomposeParDict: numberOfSubdomains 8; method simple; simpleCoeffs { n (4 2 1); delta 0.001; } It failed with the following messages: [1] [1] [1] --> FOAM FATAL ERROR: [1] allPoints.size() < 5 : 3 [1] [1] From function void immersedBoundaryFvPatch::makeInvDirichletMatrices( ) [1] in file immersedBoundaryFvPatch/immersedBoundaryFvPatchLeastSquaresFit.C at line 95. [1] FOAM parallel run aborting [1] [5] [5] [5] --> FOAM FATAL ERROR: [5] allPoints.size() < 5 : 4 [5] [5] From function void immersedBoundaryFvPatch::makeInvDirichletMatrices( ) [5] in file immersedBoundaryFvPatch/immersedBoundaryFvPatchLeastSquaresFit.C at line 95. [5] FOAM parallel run aborting [5] How should I proceed from here? I tried subdividing the immersed boundary mesh and/or refining the domain mesh but still getting the same error. Thanks in advance for your help. Chung |
March 2, 2018, 05:07 |
ibm foam extend 4.0
#16 |
deepthi
Rep Power: 13 |
Kindly share how you resolved the issue. I refined the moving cylinder in channel tutorial. Changed domain dimensions and used parallel. I tried refining the background mesh alone and the ibCylinder points alone and together also. Almost at the same instant the case crashes with the error allPoints.size() < 5 : 4. Thanks in advance. |
October 5, 2018, 18:50 |
#17 |
Emre
Rep Power: 10 |
I only encounter this headache when I try to solve in parallel. I posted my question here: mpirun gives error despite I can run my case serially EDIT: I overcame this issue by decreasing simpleCoeffs () here: mpirun gives error despite I can run my case serially Regards. Last edited by ordinary; October 7, 2018 at 15:44. Reason: fixed link to the other thread, problem solved |
Running external application in solver | dariodario32 | OpenFOAM Programming & Development | 2 | July 10, 2017 08:52 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
No running solver after successful installation of OF-2.1.x on SGI Altix UV 1000 | sebastian | OpenFOAM Installation | 16 | November 13, 2012 05:10 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Compiling and Running UDFs on an IBM Power3 | S. Hollman | FLUENT | 0 | January 6, 2005 11:23 |
