[swak4Foam] groovyBC set an initial unknown guess constant
Old   June 15, 2016, 08:13
Default groovyBC set an initial unknown guess constant
Alejandro
ancolli is on a distinguished road
My BC is as follow (for a scalar in laplacianFoam)
dT/dx=f(T,T0) (where f is nonlinear and T0 is unknown)
I solved the problem with groovyBC when T0 is known, applying N-R (Tn+1=Tn-function(Tn,T0)). it is working.
Now my problem is how to set T0 where is unknown (how to tell to groovyBC an started guessed value?
Thank u
ancolli is offline   Reply With Quote
Old   June 15, 2016, 14:32
Hesam
rapierrz is on a distinguished road
Hi Alejandro,
You can define this parameter in variables section in groovyBC.
rapierrz is offline   Reply With Quote
Old   June 15, 2016, 14:46
Alejandro
but how?
If i define T0 in variables, for example
T0=5; Eq 1.
T0=T0+ f; Eq 2.
Where f depends of flux in the last iteration.
will use for all iterations T0=5 in eq 2.
I need T0 in the right of eq. 2 to be T0 of the left for the last iteration
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
