[cfMesh] with anisotropicSources: "grading" / "scaling" does not work properly?
Old   December 3, 2016, 05:21
Default with anisotropicSources: "grading" / "scaling" does not work properly?
bizzy is on a distinguished road
as snappyHexMesh can not create proper boundary layers for my geometry, I try to use cfMesh and it makes very promising results. Unfortunately I could not find a way to add grading to my mesh. Either I do not understand the user guide correctly or there is a bug. With the following Dict, I try to implement some sort of grading from X=8 to x=16:
FoamFile
    version   2.0;
    format    ascii;
    class     dictionary;
    location  "system";
    object    meshDict;
surfaceFile "Vessel_Tank.ftr";
maxCellSize 1;
anisotropicSources
    planeFWD
    type plane;
    normal (1 0 0);
    origin (8 0 0);
    scalingDistance 8;
    scalingFactor 0.5;
surfaceMeshRefinement
    hull
        additionalRefinementLevels  7;
        surfaceFile "Vessel_Bare.stl";
        refinementThickness 0.05;
boundaryLayers
    patchBoundaryLayers
        "hull.*"
            nLayers 3;
            thicknessRatio 1.5;
            maxFirstLayerThickness 0.001;
What I get as a result is some sort of refinement, but without any grading (see screenshot). I also get the same reulst with a Box as anisotropicSource. Am I missing something or is this a bug?
bizzy is offline   Reply With Quote
Old   December 6, 2016, 15:11
Default Anisotropic meshing
Franjo Juretic
franjo_j is on a distinguished road
Send a message via Skype™ to franjo_j
It is not a bug. Your anisotropic settings mean that within 8 meters from the plane the cells shall be compressed to 50% of their original size. Therefore, the size of the cells in the x direction is 50% smaller than in other directions. The cells are compressed uniformly.
FoamFile
    version   2.0;
    format    ascii;
    class     dictionary;
    location  "system";
    object    meshDict;
maxCellSize 1;
anisotropicSources
    planeFWD
    type plane;
    normal (1 0 0);
    origin (8 0 0);
    scalingDistance 8;
    scalingFactor 0.5;
    hull
boundaryLayers
    patchBoundaryLayers
        "hull.*"
            nLayers 3;
            thicknessRatio 1.5;
Principal Developer of cfMesh and CF-MESH+
www.cfmesh.com
Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram
franjo_j is offline   Reply With Quote
Old   October 29, 2020, 07:41
Default Anisotropic mesh refinement close to free surface
Massimiliano Tarrini
massimiliano.tarrini is on a distinguished road
Send a message via Skype™ to massimiliano.tarrini
Dear Mr Juretic,
I'm using cfMesh embedded in OpenFOAM 2006. I actually believe you did a great job.
I am trying to generate grids on hull and as you probably know anisostropic refinement is needed in order to well capture wave elevation.
I tried different combination starting from shiptutorial but i'm not getting the a good result using anisotropic sources [box].
On the other side it seems that when I use localRefinement, the anisotropic mesh doesn't penetrate in the whole domain.
I can share you privately my file if you may like to give me a short hint...
kind regards
max
massimiliano.tarrini is offline   Reply With Quote
Global scaling - grid independency testing Jenny CFX 6 December 10, 2013 03:52
Could SU2_V2.0.2 work properly with continuous_adjoint.py script in parallel mode? Tommy Chen SU2 Shape Design 1 April 18, 2013 13:06
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
