swak4foam for fe40: fvOption library don't compile?
Hi
I installed fe40 and swak0.4.0 (Ubuntu 16.04) I see no obvious error and I have what seems a reasonable build that work ...except that fvOption library is missing. I see no error message in the attached log below but no mention of fvOption either. Code:
Previously compiled for OpenFOAM 4.0 Is it a known bug ( I went through the readme file and saw nothing obviously related..) Any idea what I am doing wrong? Thanks JF |
Ok
I think I can answer my question: I checked the source of fe40 and it seems there is no fvOption in it ( am I mistaken?) That will explain the fact that swak4foam does not create its Fvoption library. Does anybody knows if there is a reason why fvoptions have not been included in FE? Thanks JF |
Nonetheless, foam-extend still has the precursor to the fvOptions feature, usable by swak4Foam... look for "sourcesProperties" in the "Examples" folder in swak4Foam. |
Hi, Bruno Have you ever considered to copy the src/fvoptions in OpenFOAM 3.0.1 to foam-extend, then change some variables and paths in make/option, and compile the specific fvoptions for foam-extend. I want to have a try, but the my poor programming knowledge...... I am trapped by the different susp between OpenFOAM 3.0.1 and foam-extend 3.2 Sorry for lack of information,since my laptop is not by side...... Sent from my iPad using CFD Online Forum mobile app |
Furthermore, the other reason as to why "fvOptions" hasn't been ported to foam-extend, is because the feature is not yet 100% completed, as I mentioned in my previous post. |
2 Attachment(s)
I am trying to simulate mi case using fe40 and swak4Foam and I get this error:
--> FOAM FATAL ERROR: gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type groovyBC) on patch inlet of field U in file "/home/mapache/Documentos/aneurisma/coarse/0/U" You are probably trying to solve for a field with a generic boundary condition. those are my U and controlDict files Somebody can help me please. |
I tried running the two Example cases "pitzDailyWithExplicitPoroPlug" and "pitzDailyWithImplicitSource", and they run ok (except that they don't like the streamlines definition in the controlDict) but the momentum source defined in the "sourcesProperties" file doesn't appear to have any impact on the solution. Is there something else needed to introduce additional sources in fe-4.0? |
Hi Bruno,
Is it possible to use fvOption in fe-4.1 now? I ran into some problems and needed to use fvoption to fix them. Thanks Young |
