[waves2Foam] Problem on compiling waveIsoFoam with OpenFOAM-v2006PLUS |
August 3, 2020, 22:05 |
Maoyanjun
Rep Power: 10 |
Hello Niels and everyone,
As OpenFOAM-v2006 released, the isoAdection funtion changed a bit. I failed to compile the waveIsoFoam solver on version 2006 but I successed on version 1906 and 1912. Here are some changes I found listed below but I can not fixed it by myself. Hope some one could fixed it and update waves2foam with a waveIsoFoam solver of version 2006_PLUS. #some path of include files have changed, add below Inclued path can be added in option file of waveIsoFoam solver ``` -I$(LIB_SRC)/transportModels/geometricVoF/lnInclude \ -I$(LIB_SRC)/surfMesh/lnInclude \ ``` # Another problem is ``` alphaEqn.H:32:21: error: no matching function for call to ‘Foam::isoAdvection::advect()’ 32 | advector.advect(); | ^ In file included from waveIsoFoam.C:53: ``` As this function has change from ``` //- Advect the free surface. Updates alpha field, taking into account // multiple calls within a single time step. void advect(); ``` to ``` //- Advect the free surface. Updates alpha field, taking into account // multiple calls within a single time step. template < class SpType, class SuType > void advect(const SpType& Sp, const SuType& Su); ``` with two additional arguments. I can not know what this two arguments Sp and Su mean. So I can not fix this conflict by myself. the `waveIsoFoam` solver call the `advect()` function in `alphaEqn.H` line 32 with none of argument on version 1912 and 1906. ----------- sorry for the format of the post I do not konw why the markdown syntax doesn't work |
September 3, 2020, 08:51 |
Marc Batlle
Rep Power: 9 |
Hello everyone,
With the help of Maoyanjun I prepared a preliminary version of wavesIsoFoam for OF-v2006. You will find tiny comments wherever I added code and a "temporary" modification in the readWaveProperties file. Thanks again Maoyanjun. Marc |
If my problem diverges in OpenFOAM ver3, will it work in 5 | quarkz | OpenFOAM Running, Solving & CFD | 3 | April 26, 2018 02:09 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
[swak4Foam] problem in compiling groovyBC in OpenFoam 1.71 | javad814 | OpenFOAM Community Contributions | 4 | July 31, 2011 04:33 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 11:32 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
