ozs |
September 4, 2017 22:52 |
error when use swak4foam to calculate the mass flow rate of a cutting plane
I am new to openfoam and I use swak4foam to calculate the mass flow rate of a internal face, and I use the code in the controlDict as follows:
massFlowRate
type swakExpression;
valueType surface;
surfaceName interface;
outputControlMode outputTime;
writeStartTime off;
surface
type cuttingPlane;
functionObjectLibs ("libsampling.so");
planeType pointAndNormal;
pointAndNormalDict
basePoint (0 0.01 0); // Notet that the plane does not match up with the mesh
normalVector (0 1 0);
interpolate true;
expression "rho*U & Sf()";
accumulations (
sum
verbose true;
but error happens as follows afer running one timestep:
--> FOAM FATAL ERROR:
object of type N4Foam10isoSurfaceE is not allocated
From function const T& Foam::autoPtr<T>::operator()() const
in file /home/ouzs/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/autoPtrI.H at line 154.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/printStack.C:219
#1 Foam::error::abort() at ~/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/error.C:249
#2 Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) at ~/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/errorManip.H:85 (discriminator 4)
#3 Foam::autoPtr<Foam::isoSurface>::operator()() const at ~/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/autoPtrI.H:154
#4 Foam::sampledCuttingPlane::surface() const at ~/OpenFOAM/OpenFOAM-2.4.0/src/sampling/sampledSurface/sampledCuttingPlane/sampledCuttingPlane.H:180
#5 Foam::sampledCuttingPlane::points() const at ~/OpenFOAM/OpenFOAM-2.4.0/src/sampling/sampledSurface/sampledCuttingPlane/sampledCuttingPlane.H:155
#6 Foam::sampledCuttingPlane::print(Foam::Ostream&) const at ~/OpenFOAM/OpenFOAM-2.4.0/src/sampling/sampledSurface/sampledCuttingPlane/sampledCuttingPlane.C:467
#7 Foam::operator<<(Foam::Ostream&, Foam::sampledSurface const&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/sampling/sampledSurface/sampledSurface/sampledSurface.C:355
#8 Foam::Ostream& Foam::operator<< <Foam::sampledSurface, Foam::word, Foam::string::hash>(Foam::Ostream&, Foam::HashPtrTable<Foam::sampledSurface, Foam::word, Foam::string::hash> const&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/HashPtrTableIO.C:232
#9 Foam::SurfacesRepository::writeData(Foam::Ostream&) const at ~/OpenFOAM/ouzs-2.4.0/swak4Foam/Libraries/swak4FoamParsers/repositories/SurfacesRepository.C:222
#10 Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const at ~/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/db/regIOobject/regIOobjectWrite.C:100
#11 Foam::objectRegistry::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const at ~/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/db/objectRegistry/objectRegistry.C:364
#12 Foam::Time::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const at ~/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/db/Time/TimeIO.C:518
#13 Foam::regIOobject::write() const at ~/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/db/regIOobject/regIOobjectWrite.C:134
#14 ? at ~/OpenFOAM/OpenFOAM-2.4.0/applications/solvers/heatTransfer/buoyantPimpleFoam/buoyantPimpleFoam.C:101
#15 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#16 ? at ??:?
Aborted (core dumped)
so, why the error happens? I am looking forward for your help.
thanks.
Geson
