[IHFOAM] IHFOAM Vegetation Module
Like Tree3Likes
  • 1 Post By IHFOAM Team
  • 1 Post By dylan_OF
Old   September 14, 2017, 05:01
Default IHFOAM Vegetation Module
IHFOAM Team's Avatar
IHFOAM The Environmental Hydraulics Institute "IHCantabria"
IHFOAM Team is on a distinguished road
Dear all,
You can now download the fully validated (Maza et al. 2015, 2016) IHFOAM vegetation module here (code & a validation case):
https://github.com/IHCantabria/ihFOAM_mangroves
It works for OpenFOAM-v1612+ and OpenFOAM-v1706.
You can find more information in:
http://ihfoam.ihcantabria.com
http://www.openfoam.com/releases/ope...ave-generation
Regards,
IHFOAM Team.
Daniel_Khazaei likes this.
http://ihfoam.ihcantabria.com/
IHFOAM Team is offline   Reply With Quote
Old   July 3, 2018, 05:30
We are very happy to announce that you can find the fluid-vegetation module in OpenFOAM v1816 release:
https://www.openfoam.com/releases/op...ve-interaction
Two papers were published:
Tsunami wave interaction with mangrove forests: A 3-D numerical approach.
Maza, M, Lara, J.L., & Losada, I.J. [2015]
Coastal Engineering [Vol.98, pp. 33-54]
https://doi.org/10.1016/j.coastaleng.2015.01.002
Solitary wave attenuation by vegetation patches.
Maza, M, Lara, J.L., & Losada, I.J. [2016]
Advances in Water Resources [Vol.98, pp. 159-172]
hhttps://doi.org/10.1016/j.advwatres.2016.10.021
Regards,
IHFOAM Team
Old   March 5, 2020, 02:36
Masoumeh
ms.hashempour is on a distinguished road
I have this error with GUI and I cant click on Toposet:
ERROR!!
--> FOAM FATAL ERROR:
Unable to find cellZone c0
Valid cellZones are:0()
From function virtual bool Foam::fv::multiphaseMangrovesSource::read(const Foam::dictionary&)
in file fvOptions/multiphaseMangrovesSource/multiphaseMangrovesSource.C at line 235.
FOAM exiting
ms.hashempour is offline   Reply With Quote
Old   December 17, 2020, 12:18
Default iHFoamMangrove - wmake fvOptions Error
Luiz Ferreira
lppferreira is on a distinguished road
I am using OpenFOAM-v1812 at wsl2 Ubuntu 18.04 and I have already compiled iHFoam solver.
I am trying to compilate IHFoamMangrove solver but when I run wmake at /opt/OpenFOAM/OpenFOAM-v1812/src/fvOptions, after copied multiphaseMangrovesSource" and "multiphaseMangrovesTurbulenceModel" folders into src/fvOptions/ and edited fvOptions/Make/files as
>>/* iHFoam Mangrove */
>>multiphaseMangrovesTurbulenceModel/multiphaseMangrovesTurbulenceModel.C
LIB = $(FOAM_LIBBIN)/libfvOptions"
appears the folllowing error message:
" multiphaseMangrovesSource/multiphaseMangrovesSource.C: In member function ‘virtual bool Foam::fv::multiphaseMangrovesSource::read(const Foam::dictionary&)’:
multiphaseMangrovesSource/multiphaseMangrovesSource.C:193:52: error: invalid initialization of reference of type ‘const Foam::word&’ from expression of type ‘Foam::ITstream’
const word& zoneName = modelDict.lookup("cellZone");
/opt/OpenFOAM/OpenFOAM-v1812/wmake/rules/General/transform:34: recipe for target '/opt/OpenFOAM/OpenFOAM-v1812/build/linux64GccDPInt32Opt/src/fvOptions/multiphaseMangrovesSource/multiphaseMangrovesSource.o' failed
make: *** [/opt/OpenFOAM/OpenFOAM-v1812/build/linux64GccDPInt32Opt/src/fvOptions/multiphaseMangrovesSource/multiphaseMangrovesSource.o] Error 1 "
How can I fix it?
Thanks!
lppferreira is offline   Reply With Quote
Old   April 7, 2021, 20:50
Dylan James
dylan_OF is on a distinguished road
Originally Posted by lppferreira View Post
How can I fix it?
Thanks!
hi,I had the same problem as you, did you fix it?
baccaperina likes this.
dylan_OF is offline   Reply With Quote
Old   December 1, 2022, 21:21
GUOhq
GUOhq is on a distinguished road
I am using OpenFOAM-v2006 ,I tested mangroves tutorials.The wave type is solitary wave,Can regular waves be applied to this model?
I don't consider mangroves. I use the kE model of the tutorials to test regular waves. The wave height at the end of the flume decreases obviously with time. Is there any good way to deal with this problem?
Thanks!
GUOhq is offline   Reply With Quote
Old   December 5, 2022, 16:16
Hi there,
Yes, you can generate waves, please copy the set-up of any waves tutorial provided in the official release (stokesI for example).
In order to reduce wave damping, please consider for example checking your cell discretization and use the Devolder--Larsen&Fuhtman approach. link
Best,
IHFOAM Team
Vegetation Module in IHFOAM has been released! MarEMotion OpenFOAM Announcements from Other Sources 0 September 13, 2017 10:53
[foam-extend.org] Module file foam-extend 3.2 CentOS cluster KarthickRajkumar OpenFOAM Installation 2 March 26, 2017 13:52
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
Lamboot trouble r2d2 OpenFOAM Installation 4 October 17, 2005 04:27
