[SOWFA] Floating Point Exception for SOWFA runs |
November 29, 2017, 17:39 |
Dear Users,
I have recently installed OpenFOAM 2.4.0 in University of Texas at Austin's TACC supercomputer Stampede2 and NREL's SOWFA on top of it. I was able to run tutorial cases in OpenFOAM, but when I try to run SOWFA example cases, I am getting a Floating Point Exception error. I was able to run blockMesh, checkMesh, setFieldsABL commands required for SOWFA. Below is the initial lines of the log file. Build : 2.4.0-dcea1e13ff76 Exec : ABLSolver Date : Nov 29 2017 Time : 10:40:53 Host : "c455-093.stampede2.tacc.utexas.edu" PID : 172074 Case : /home1/03798/nany717/OpenFOAM/nany717-2.4.0/exampleCases/neutral_test1 nProcs : 1 sigFpe : Floating point exception trapping - not supported on this platform fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations I have checked the numericals in the example cases, there is no problem with them. Did anyone face the same issue? If so, what did you do thereafter? Please advise hot to proceed. Thank you Sudheer |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
A floating point exception has occurred: floating point exception [Overflow]. | starlight | STAR-CCM+ | 4 | May 4, 2016 09:08 |
A floating point exception - SEM Model | yansheng | STAR-CCM+ | 1 | April 4, 2016 04:57 |
Floating point exception from twoPhaseEulerFoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 1 | March 19, 2016 13:56 |
FATAL: floating point exception (AMG divergence) | KeganLeckness | FLUENT | 1 | December 2, 2015 11:10 |
