March 6, 2018, 16:13 |
PyFoam 6.6.9 installation problems
Klaus
Rep Power: 22 |
PyFoam is not working properly. I installed it using pip so I can plot the residuals from my new OpenFoam 5.0 installation. Issue 1: the installed gnuplot version 5.2.2-7 is not recognized I tested gnuplot and it works fine. Issue 2: pyFoamVersion.py seems to identify the installed OpenFoam 5.0 as a fork version Issue 3: The residual plot using pyFoamPlotRunner.py doesn't work at all. pyFoamVersion.py gives the following information: Code:
Machine info: Linux | test | 4.15.7-60.current | #1 SMP PREEMPT Thu Mar 1 13:02:55 UTC 2018 | x86_64 | Python version: 2.7.14 (default, Feb 17 2018, 10:27:51) [GCC 7.3.0] Python executable: /usr/bin/python2.7 Python 2.7 is one development platform for PyFoam (along with Python 3) PYTHONPATH is not set Location of this utility: /usr/bin/pyFoamVersion.py PyFoam WARNING on line 202 of file /usr/lib/python2.7/site-packages/PyFoam/FoamInformation.py : Basedir /home/klaus/foam for fork extend does not exist or is not a directory Version 5.0 (reported as number 5.0 )Fork openfoam of the installed 1 versions: openfoam-5.0 : /home/klaus/OpenFOAM/OpenFOAM-5.0 pyFoam-Version: 0.6.9 Path where PyFoam was found (PyFoam.__path__) is ['/usr/lib/python2.7/site-packages/PyFoam'] Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/klaus/.pyFoam/pyfoamrc'), ('directory', '/home/klaus/.pyFoam/pyfoamrc.d')] Configuration files (used): [] Installed libraries: cython : No Not used. Maybe will by used later to spped up parts of PyFoam cProfile : Yes docutils : No Not necessary. Needed for RestructuredText to HTML conversion Gnuplot : No Not a problem. Version from ThirdParty is used hotshot : Yes line_profiler : No Not a problem. Can't profile using this library ipdb : No Not necessary. Only makes debugging more comfortable IPython : No Not necessary. But the interactive shell may be more comfortable matplotlib : No Only Gnuplot-plotting possible mercurial : No Not a problem. Used for experimental case handling pytest : No Only needed for running the unit-tests (developers only) numpy : Yes version: 1.14.1 openpyxl : No Not a problem. Only used for exporting pandas-data to Excel-files (advanced). If xlsxwriter is installed it will handle this (xlsxwriter is recommended anyway) xlsxwriter : No Not a problem. Only used for exporting pandas-data to XLSX-files (advanced). If openpyxl is installed then this module can handle that pandas : No Not a problem. Only used for handling of advanced data-handling ply : No Not a problem. Version from ThirdParty is used profile : Yes psyco : No Not a problem. Acceleration not possible PyQt4 : No Only some experimental GUI-stuff relies on this PyQt4.Qwt5 : No Only an alternate plotting back-end scipy : No Not yet used. Possibly use signal-fitting etc Tkinter : Yes version: $Revision: 81008 $ twisted : No Not yet used. Possibly reimplement MetaServer with it vtk : No Not a problem. Only used for some utilities xlwt : No Not a problem. Only used for exporting pandas-data to Excel-files xlrd : No Not a problem. Only used for importing Excel-files to pandas-data requests : Yes version: 2.18.4 zeroconf : No Not a problem. Necessary to find existing runs. Install with 'pip install zeroconf' psutil : No Not a problem. Provides better calculation of the maximum used memory PyFoam.ThirdParty.ply.yacc : Yes version: 3.9 PyFoam.ThirdParty.Gnuplot : Yes version: 1.8 PyFoam.ThirdParty.tqdm : Yes version: 4.8.4 PyFoam.ThirdParty.IPy : Yes version: 0.51 PyFoam.ThirdParty.pyratemp : Yes version: 0.2.0 PyFoam.ThirdParty.six : Yes version: 1.10.0 PyFoam.ThirdParty.winhacks : Yes Library locations cProfile : /usr/lib/python2.7/cProfile.py hotshot : /usr/lib/python2.7/hotshot/__init__.py numpy : /usr/lib/python2.7/site-packages/numpy/__init__.pyc profile : /usr/lib/python2.7/profile.py PyFoam.ThirdParty.Gnuplot : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/Gnuplot/__init__.pyc PyFoam.ThirdParty.IPy : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/IPy.pyc PyFoam.ThirdParty.ply.yacc : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/ply/yacc.pyc PyFoam.ThirdParty.pyratemp : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/pyratemp.pyc PyFoam.ThirdParty.six : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/six.pyc PyFoam.ThirdParty.tqdm : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/tqdm/__init__.pyc PyFoam.ThirdParty.winhacks : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/winhacks.pyc requests : /usr/lib/python2.7/site-packages/requests/__init__.pyc Tkinter : /usr/lib/python2.7/lib-tk/Tkinter.pyc Checking additional envirnoment variables Checking for PYFOAM_DIR : Location of the PyFoam-installation. Not strictly necessary PYFOAM_DIR missing from environment Checking for PYFOAM_SITE_DIR : Location of non-PyFoam-disctributions script. Set and used by some Foam-distributions PYFOAM_SITE_DIR missing from environment User information Username: klaus Temporary directory: /tmp/PyFoam_klaus Public key: 3be4f830574208f17776e286f2609b:052e3e1262b0781fa5026f3281772dab Klaus |
March 6, 2018, 19:29 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
October 2, 2022, 05:56 |
Sanjay R
Rep Power: 3 |
Have you solved the problem? since I too seem to have the same issue...
[PyFoam] Problems with installing PyFoam | Christoph_84 | OpenFOAM Community Contributions | 34 | October 26, 2021 11:25 |
[OpenFOAM.com] v1606+ Problems of installation on iMac | Intercooled | OpenFOAM Installation | 4 | November 15, 2016 20:22 |
Problems installing SVN in Ubuntu (for later installing PyFoam for OpenFOAM) | immortality | Lounge | 2 | May 24, 2014 03:05 |
Problems with installation | batta31 | OpenFOAM Installation | 2 | September 4, 2012 07:01 |
installation problems on upgrade from win 3.26 to | mic | Siemens | 5 | June 20, 2007 09:40 |
