[cfMesh] How to get rid of the cell refinement at the farfield boundary
Old   April 5, 2018, 13:52
Default How to get rid of the cell refinement at the farfield boundary
Klaus
klausb will become famous soon enough
I want to create a 2D mesh with cfMesh for airfoils analysis. The mesh has the following requirements:
1: O-mesh
2: y+ = 5 boundary layer
3: 300 cells at the airfoil surface
4: About 50.000 cells in total
5: Gradually coarser mesh starting at the airfoil boundary layer, ending at the farfield domain boundary
The airfoil contour with a blunt trailing edge and the farfield boundary are defined in airfoil_farfield.stl and are called inside the file airfoil and farfield respectively.
So far I am able to create a boundary layer mesh around the airfoil (still with too many cells) but at the same time there's always mesh refinement at the farfield boundary where the mesh should be very coarse.
How can I avoid the refinement at the farfield boundary?
| \\      /  F ield         | OpenFOAM GUI Project: creativeFields           |
|  \\    /   O peration     | Version:  0.8.9.0                              |
|   \\  /    A nd           | Web: www.c-fields.com                          |
|    \\/     M anipulation  |                                                |
FoamFile
version    2;
format    ascii;
class    dictionary;
location    "system";
object    meshDict;
maxCellSize         5;
minCellSize         0.002;
surfaceFile        "airfoil_farfield.stl";
localRefinement
  "farfield.*"
cellSize 5;
boundaryLayers
    patchBoundaryLayers
        "airfoil.*"
        nLayers                 20;
        boundaryCellSize                0.002;
        maxFirstLayerThickness             0.01;
        thicknessRatio          1.2;
attached a picture of the mesh
klausb is offline   Reply With Quote
Old   May 7, 2018, 04:46
JD
dickcruz is on a distinguished road
What does it look like when you turn the BL settings off?
dickcruz is offline   Reply With Quote
Old   May 7, 2018, 15:31
Default it looks the same...
Klaus
the mesh looks the same just without a boundary layer mesh at the airfoil surface.
Any idea how to avoid the refinement at the farfield boundary and how to create a constantly coarser mesh towards the farfield boundary?
Old   May 28, 2018, 08:04
Dr. Peyman Davvalo Khongar
peyman.davvalo.khongar is on a distinguished road
Originally Posted by klausb View Post
1: O-mesh
FoamFile
version    2;
format    ascii;
class    dictionary;
location    "system";
object    meshDict;
maxCellSize         5;
minCellSize         0.002;
localRefinement
  "farfield.*"
cellSize 5;
boundaryLayers
    patchBoundaryLayers
        "airfoil.*"
        nLayers                 20;
        thicknessRatio          1.2;
Moi!
If I understand it correctly, you want to have boundary layers around your airfoil face but you dont want any refinement at farfield face. isn't it?
If this is the case, why do you use localRefinement for farfield face? if you dont want that face to be refined, dont use it in localRefinement. Then it should be like this:
maxCellSize         5;
minCellSize         0.002;
localRefinement
boundaryLayers
    patchBoundaryLayers
        "airfoil.*"
        nLayers                 20;
        thicknessRatio          1.2;
If this is not your problem, please explain more.
Moikka,
Peyman
peyman.davvalo.khongar is offline   Reply With Quote
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
[snappyHexMesh] Edge Refinement fracasce OpenFOAM Meshing & Mesh Conversion 3 December 2, 2017 14:30
[snappyHexMesh] sHM refinement away from surface nholt OpenFOAM Meshing & Mesh Conversion 1 June 14, 2016 15:36
Radiation interface hinca CFX 15 January 26, 2014 18:11
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 03:32
