Possible to edit src files in openfoam installation
Hi Foamers,
Is it possible to edit the Openfoam-v1806/src/finiteVolume/.... any files inside this directory? In particular, I want to change the isoAdvector definition to suit my case. I copied all the files from isoAdvection to the user directory. Then I changed the file names to myisoAdvection (.C,.H ) and also the function names inside them. All these changed files, I have in the user defined solver directory namely myinterIsoFoam. 1. Is it right procedure to do ? Copying src files from the installation folder and changing it. 2. After compiling, I get undefined reference errors. I don't change any function definition. Just the name of functions I change. How to get rid of these errors ? ex: myinterIsoFoam.C:(.text._ZNK4Foam14myisoAdvection4 typeEv[_ZNK4Foam14myisoAdvection4typeEv]+0x3): undefined reference to `Foam::myisoAdvection::typeName' Make/linux64GccDPInt32Opt/myinterIsoFoam.o: In function `main': myinterIsoFoam.C:(.text.startup+0x2b6e): undefined reference to `Foam::myisoAdvection::myisoAdvection(Foam::Geomet ricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&)' myinterIsoFoam.C:(.text.startup+0x4626): undefined reference to `Foam::myisoAdvection::myadvect()' myinterIsoFoam.C:(.text.startup+0x6af1): undefined reference to `Foam::myisoAdvection::myadvect()' myinterIsoFoam.C:(.text.startup+0x80d3): undefined reference to `Foam::myisoAdvection::myisoAdvection(Foam::Geomet ricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&)' collect2: error: ld returned 1 exit status This is what I get after compilation. Kindly help me to solve this. Thanks. |
Solved.
http://www.tfd.chalmers.se/~hani/kur...ated050118.pdf The above file from chalmers university explains it. |
