[waves2Foam] waves2foam freezing when starting time loop... |
June 13, 2018, 17:27 |
Peter Ladefoged
Dear Niels,
First of all I would like to say that I really enjoy working with waves2foam and I am eager to learn as I will be using OpenFOAM for my master thesis. So thank you in helping developing this toolbox and manual for unexperienced users as myself... I am currently working on a special course at DTU and experiencing a problem with the tutorials - not all tutorials however, as standingWave is working fine. I am using OpenFOAM v1712 and running via the cluster on the gbar. My problem is that when I try to run for instance the waveFlume or bejiBattjes tutorial I can run the first commands, i.e. blockMesh, waveGaugesNProbes, setWaveParameter, setWaveField all work. However when I get to running the solver waveFoam the terminal freezes at the "starting time loop" and no iterations follow... I have figured out that the solver will run however if I delete the last function lines in the controlDict file : functions { #includeIfPresent "../waveGaugesNProbes/surfaceElevationAnyName_controlDict; } I therefore suspect there might be a problem with the waveGaugesNProbes? Do you have any suggestions as to what might be the problem I am facing? Kind Regards Peter |
February 10, 2020, 07:16 |
Jinshi Chen
Rep Power: 6 |
Hi did you figure out the reason behind this? I am having similar situation right now. However, my solver still freezes after I delete that line. I have run the same case successfully. Thus I don't know what's going on.
Best, JC |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
Simulation stops at Starting time loop | JMaverick93 | OpenFOAM Running, Solving & CFD | 3 | March 18, 2018 06:08 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
