OpenFOAM 4.1: Unknown function type surfaceElevation
Hi everyone,
I've been trying to get surfaceElevation to work since (r2118) but I'm still getting: FOAM FATAL ERROR: Unknown function type surfaceElevation Wondering if I'm still missing something. I downloaded the updated files and using the update files in my case. Everything else is working. I'm using OpenFOAM4.1, do I need to switch over to OpenFOAM+1712? Thanks, Eric |
Hi Eric,
I have not looked into compilation for OpenFoam-4.1 (4.0 or 5.0) versions. Either you switch to 1712+ or you make the necessary modifications to the compilation scripts (and potentially source code) yourself. Kind regards, Niels |
Eric, did you manage to solve the problem ? I have a similar problem.
