[waves2Foam] Questions about relaxation zones |
September 25, 2015, 08:21 |
Xiantao Zhang
Rep Power: 11 |
Hi Niels,
I have a question about the function of relaxationzone in the inlet boundary. It can absorb the wave reflected by the body in the numerical wave tank? which is just like the relaxation zone in the outlet boundary absorbing the waves to prevent reflection from the outlet boundary. Kind Regards Xiantao |
September 25, 2015, 08:35 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Yes, that is correct. If you look in my Ph.D. thesis, you will see that I have used it to absorp waves from a fully reflecting wall and a standing wave pattern is obtained in the inner part of the computational domain.
Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
September 25, 2015, 09:52 |
Xiantao Zhang
Rep Power: 11 |
Hi Niels,
Thanks for your reply. could you tell me the title of your phd thesis? Kind Regards Xiantao |
October 18, 2015, 02:54 |
Xiantao Zhang
Rep Power: 11 |
Hi Niels,
Is there any principle for choosing the length of the relaxation zone in the inlet boundary ( wave generation boundary), like one wave length or two wave length?? Best regards xiantao |
October 24, 2015, 01:53 |
Aloha
Rep Power: 10 |
Hi,Neil & waveFoamers
I have a question about the relaxation zone shpe,is the rectanglar shape applicalbe to the 3D tank? Thank you in advance. |
October 24, 2015, 04:46 |
Rep Power: 37 |
Good morning,
@aap1e: Take a look at the tutorials, especially 3DWaves. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. Last edited by wyldckat; August 25, 2018 at 13:14. Reason: removed answers to other posts that were on the main thread |
October 5, 2017, 23:57 |
a question about relaxation zone of wave2foam
Xiannan Meng
Rep Power: 8 |
Dear all,
I am a beginner for openfoam and waves2foam. I have a question in relation to waves2foam. An inlet relaxation zone and an outlet relaxation zone needs to be defined. I can understand the reason why to define a outlet relaxation zone. However I don't understand why an inlet relaxation zone must be defined? Could some one help me explain it? Many thanks. Regards, Xiannan |
October 6, 2017, 02:25 |
#8 | |
Ahmed Elhanfi
Rep Power: 11 |
An inlet relaxation zone is required to absorb waves reflected/scattered from the model you are testing so that these waves do not affect your incoming waves prescribed at the inlet boundary. This works as an absorbing wavemaker similar to that used in some physical wave tanks/flumes. Regards, Ahmed |
October 6, 2017, 06:16 |
#9 | |
Xiannan Meng
Rep Power: 8 |
Hi Ahmed, thanks a lot for your explanation. Now I have an another question (sorry for bothering you again). I try to see relaxation zone of tutorial waveFlue by means of relaxationZoneLayout utility. To my surprise I cannot find inlet relaxation zone (I know that they define inlet relaxation zone as well outlet relaxation zone). Do you know if I did something wrong or whatever? see the picture |
October 11, 2017, 13:13 |
#10 | |
Kun Zheng
Rep Power: 8 |
I use the relaxationZoneLayout to show the inlet and outlet relaxation zone, As shown in the attached figure. Copy the files (constant/polyMesh/blockMeshDict; constant/waveProperties.input ) in "waveFlume" and replace the corresponding files in "relaxationZoneLayout". |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
Lets talk about relaxation factor optimization | chriss85 | OpenFOAM Running, Solving & CFD | 35 | June 21, 2019 09:54 |
Automatic Relaxation factors | Ivan | OpenFOAM Programming & Development | 1 | June 30, 2016 03:47 |
Bug/Problem: sonicFoam results depend on relaxation factor | chriss85 | OpenFOAM Bugs | 1 | November 5, 2015 08:22 |
What's happening to my solution for lower relaxation factor | casesam | OpenFOAM Running, Solving & CFD | 3 | October 22, 2015 01:25 |
