[waves2Foam] New wave theory coded in FORTRAN, how to add to waves2Foam?
Old   August 28, 2017, 06:06
Default New wave theory coded in FORTRAN, how to add to waves2Foam?
Kun Zheng
Kun_zheng is on a distinguished road
Hi all,
I want to add a new wave theory to waves2Foam. Did anyone know how to do it?
The wave theory is not analytic, I have a fortran code to calculated it every time step. What I want is to add the subroutines of fortran code to the waves2Foam.
I think it is possible to compile the fortran code into an object file. Then link the Cpp file and object file. But I failed.
If anyone know how to do it, could you please give me some guidances.
Thank you for your time!
Kun
Kun_zheng is offline   Reply With Quote
Old   August 28, 2017, 11:32
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Kun,
You most likely need to create an interface between fortran and C++; at least this was the approach taken for OceanWave3D. Consequently, I can only recommend that you look into both the source code of OceanWave3D and the external wave theory oceanWave3D to get a feel for the coupling.
In the present implementation, OceanWave3D exists as a library, which is executed through OpenFoam.
May I ask what the external method does?
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is online now   Reply With Quote
Old   August 29, 2017, 05:19
Kun Zheng
Hi Niels,
I find it. I think that is what I need. Thank you !
The external model I used is named Green Naghdi equations. It is a strong nonlinear wave model.
Best regards,
Kun
Old   August 29, 2017, 07:01
ngj
Hi Kun,
That is very interesting. If you get it to work, it would be great to include in waves2Foam. Please consider.
Kind regards
Niels
Old   August 29, 2017, 15:11
Kun Zheng
Originally Posted by ngj View Post
Hi Kun,
Kind regards
Niels
Hi Niels,
After a minor modification, I get trouble in running the case " couplingOceanWave3D ". Could you see what I did and help me fix the trouble ?
Under your suggestion, I find the source code of OceanWave3D in " **/waves2Foam/ThirdParty/OceanWave3D-Fortran90/src/main ".
So I add a fortran code of " hello world " to test what would happen if a new subroutine is added in " oceanWave3D.C ". And then the test-subroutine is called in "oceanWave3D.C" like other previous subroutines.
After that I re-compile the " **/waves2Foam/ThirdParty " and the " **/waves2Foam/src ".
No errors came out till now.
Then I run the case "couplingOceanWave3D", the log of setWaveField says:
" symbol lookup error: **/platforms/linux64GccDPInt32Opt/lib/libwaves2Foam.so: undefined symbol: test "
But there was no errors when I compile the lib. I do not understand what was wrong. Could you help me ?
Thank you very much for your time !
Best regards,
Kun
Old   August 29, 2017, 16:41
ngj
Hi Kun,
The compilation gets a new pull from the git for OceanWave3D every time, so that might overwrite your modifications. I did not make the fortran side of the coupling, so I can only hypothesise on how things work. Right now, I do not have a good suggestion besides making a simpler test outside of OceanWave3D source.
Kind regards
Niels
Old   August 30, 2017, 05:58
Kun Zheng
Hi Niels,
Yes, I have checked the modification. It is still there. Thank you so much, you really help a lot ! I think I have to do more tests to find out where is the problem. Hope to make a progress soon.
Best regards,
Kun
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 10:23
Waves2Foam help needed, inserting multiple wave probes chia87 OpenFOAM Running, Solving & CFD 1 February 10, 2016 05:15
Add a FORTRAN object to wmake compilation directives vitors OpenFOAM Programming & Development 1 April 9, 2014 15:25
How to call FORTRAN files as UDF? Ehsan-F Fluent UDF and Scheme Programming 6 September 11, 2012 12:03
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
