xiaochao |
June 14, 2017 07:07 |
OFv4.1 with the tutorial waveFlume
Hello, everyone!
I have just installed the waves2Foam library on OFv4.1 and now am running the tutorial waveFlume. Some error messages are displayed, does anyone know what the problem is.
Thanks.
Xiaochao
The error messages are as follows:
| \\ / O peration | Version: 4.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.1
Exec : waveFoam
Date : Jun 12 2017
Time : 16:01:57
Host : "ubuntu"
PID : 6681
Case : /home/xuli/OpenFOAM/xuli-4.1/applications/utilities/waves2Foam/tutorials/waveFoam/waveFlume
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading g
Reading waveProperties
Reading field pd
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Calculating field g.h
Selecting turbulence model type laminar
time step continuity errors : sum local = 0, global = 0, cumulative = 0
DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
--> FOAM Warning :
From function void Foam::timeControl::read(const Foam::dictionary&)
in file db/functionObjects/timeControl/timeControl.C at line 89
Reading "/home/xuli/OpenFOAM/xuli-4.1/applications/utilities/waves2Foam/tutorials/waveFoam/waveFlume/system/controlDict.functions.surfaceElevationAnyName" from line 3 to line 1614
Using deprecated 'outputControl'
Please use 'writeControl' with 'writeInterval'
--> FOAM Warning :
From function bool Foam::functionObjectList::read()
in file db/functionObjects/functionObjectList/functionObjectList.C at line 671
Caught FatalError
--> FOAM FATAL ERROR:
Unknown function type surfaceElevation
Valid functions are :
4
patchProbes
probes
sets
surfaces
From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
in file db/functionObjects/functionObject/functionObject.C at line 100.
deltaT = 0.0011976
Time = 0.0011976
PIMPLE: iteration 1
MULES: Solving for alpha1
Liquid phase volume fraction = 0 Min(alpha1) = 0 Max(alpha1) = 1
Relaxing time: 0.03 s
LHS and RHS of + have different dimensions
dimensions : [0 3 -1 0 0 0 0] + [0 3 -2 0 0 0 0]
ces
From function Foam::dimensionSet Foam::operator+(const Foam::dimensionSet&, const Foam::dimensionSet&)
in file dimensionSet/dimensionSet.C at line 489.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::operator+(Foam::dimensionSet const&, Foam::dimensionSet const&) at ??:?
#3 Foam::tmp<Foam::GeometricField<Foam::typeOfSum<double, double>::type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::operator+<double, double, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) at ??:?
#4 main at ??:?
#5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#6 ? at ??:?
Aborted (core dumped)
