Problems compiling with OpenFOAM 3.0.1
*Need Help Compiling* I've been following step by step of phmusi, and when i ./Allwmake, this is the error i've got
===================================== COMPILE SOLVERS ===================================== Making dependency list for source file waveFoam.C g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam30/src/transportModels -I/opt/openfoam30/src/transportModels/incompressible/lnInclude -I/opt/openfoam30/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam30/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/openfoam30/src/TurbulenceModels/incompressible/lnInclude -I/opt/openfoam30/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/fvOptions/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/sampling/lnInclude -DOFVERSION=300 -DEXTBRANCH=0 -DXVERSION=0 -I/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/src/waves2Foam/lnInclude -I/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/src/waves2FoamSampling/lnInclude -I/usr/include -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c waveFoam.C -o Make/linux64GccDPInt32Opt/waveFoam.o g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam30/src/transportModels -I/opt/openfoam30/src/transportModels/incompressible/lnInclude -I/opt/openfoam30/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam30/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/openfoam30/src/TurbulenceModels/incompressible/lnInclude -I/opt/openfoam30/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/fvOptions/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/sampling/lnInclude -DOFVERSION=300 -DEXTBRANCH=0 -DXVERSION=0 -I/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/src/waves2Foam/lnInclude -I/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/src/waves2FoamSampling/lnInclude -I/usr/include -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/waveFoam.o -L/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib \ -limmiscibleIncompressibleTwoPhaseMixture -lturbulenceModels -lincompressibleTurbulenceModels -lfiniteVolume -lfvOptions -lmeshTools -lsampling -L/home/oecu/OpenFOAM/oecu-3.0.1/platforms/linux64GccDPInt32Opt/lib -lwaves2Foam -lwaves2FoamSampling -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl \ -lm -o /opt/openfoam30/platforms/linux64GccDPInt32Opt/bin/waveFoam /usr/bin/ld: cannot find -lwaves2Foam /usr/bin/ld: cannot find -lwaves2FoamSampling collect2: error: ld returned 1 exit status make: *** [/opt/openfoam30/platforms/linux64GccDPInt32Opt/bin/waveFoam] Error 1 ===================================== COMPILE PRE-PROCESSING ===================================== make[1]: Entering directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/preProcessing/faceSetToSTL' Making dependency list for source file faceSetToSTL.C could not open file foamTime.H for source file faceSetToSTL.C due to No such file or directory make[1]: Leaving directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/preProcessing/faceSetToSTL' make[1]: Entering directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/preProcessing/faceSetToSTL' g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/triSurface/lnInclude -I/opt/openfoam30/src/finiteVolume/lnInclude -DOFVERSION=301 -DEXTBRANCH=0 -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c faceSetToSTL.C -o Make/linux64GccDPInt32Opt/faceSetToSTL.o g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/triSurface/lnInclude -I/opt/openfoam30/src/finiteVolume/lnInclude -DOFVERSION=301 -DEXTBRANCH=0 -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/faceSetToSTL.o -L/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib \ -lOpenFOAM -ltriSurface -lfiniteVolume -lOpenFOAM -ldl \ -lm -o /home/oecu/OpenFOAM/oecu-3.0.1/platforms/linux64GccDPInt32Opt/bin/faceSetToSTL make[1]: Leaving directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/preProcessing/faceSetToSTL' make[1]: Entering directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' Making dependency list for source file relaxationZoneLayout.C could not open file foamTime.H for source file relaxationZoneLayout.C due to No such file or directory make[1]: Leaving directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' make[1]: Entering directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/finiteVolume/lnInclude -DOFVERSION=301 -DEXTBRANCH=0 -I/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/src/waves2Foam/lnInclude -I/usr/include -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c relaxationZoneLayout.C -o Make/linux64GccDPInt32Opt/relaxationZoneLayout.o g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/finiteVolume/lnInclude -DOFVERSION=301 -DEXTBRANCH=0 -I/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/src/waves2Foam/lnInclude -I/usr/include -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/relaxationZoneLayout.o -L/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib \ -lfiniteVolume -L/home/oecu/OpenFOAM/oecu-3.0.1/platforms/linux64GccDPInt32Opt/lib -lwaves2Foam -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl \ -lm -o /home/oecu/OpenFOAM/oecu-3.0.1/platforms/linux64GccDPInt32Opt/bin/relaxationZoneLayout /usr/bin/ld: cannot find -lwaves2Foam collect2: error: ld returned 1 exit status make[1]: *** [/home/oecu/OpenFOAM/oecu-3.0.1/platforms/linux64GccDPInt32Opt/bin/relaxationZoneLayout] Error 1 make[1]: Leaving directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' make: *** [relaxationZoneLayout] Error 2 ===================================== COMPILE POST-PROCESSING ===================================== make[1]: Entering directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/postProcessing/postProcessWaves2Foam' Making dependency list for source file postProcessWaves2Foam.C could not open file foamTime.H for source file postProcessWaves2Foam.C due to No such file or directory make[1]: Leaving directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/postProcessing/postProcessWaves2Foam' make[1]: Entering directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/postProcessing/postProcessWaves2Foam' g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/finiteVolume/lnInclude -I/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/src/waves2Foam/src/lnInclude -I/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/src/waves2FoamProcessing/lnInclude -I/usr/include -DOFVERSION=301 -DEXTBRANCH=0 -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c postProcessWaves2Foam.C -o Make/linux64GccDPInt32Opt/postProcessWaves2Foam.o g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/finiteVolume/lnInclude -I/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/src/waves2Foam/src/lnInclude -I/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/src/waves2FoamProcessing/lnInclude -I/usr/include -DOFVERSION=301 -DEXTBRANCH=0 -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/postProcessWaves2Foam.o -L/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib \ -lOpenFOAM -lfiniteVolume -L/home/oecu/OpenFOAM/oecu-3.0.1/platforms/linux64GccDPInt32Opt/lib -lwaves2Foam -lwaves2FoamProcessing -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl \ -lm -o /home/oecu/OpenFOAM/oecu-3.0.1/platforms/linux64GccDPInt32Opt/bin/postProcessWaves2Foam /usr/bin/ld: cannot find -lwaves2Foam /usr/bin/ld: cannot find -lwaves2FoamProcessing collect2: error: ld returned 1 exit status make[1]: *** [/home/oecu/OpenFOAM/oecu-3.0.1/platforms/linux64GccDPInt32Opt/bin/postProcessWaves2Foam] Error 1 make[1]: Leaving directory `/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/applications/utilities/postProcessing/postProcessWaves2Foam' make: *** [postProcessWaves2Foam] Error 2 ===================================== COMPILATION DONE ===================================== When i try to compile with wmake, i also got this error, g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam30/src/transportModels -I/opt/openfoam30/src/transportModels/incompressible/lnInclude -I/opt/openfoam30/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam30/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/openfoam30/src/TurbulenceModels/incompressible/lnInclude -I/opt/openfoam30/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/fvOptions/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/sampling/lnInclude -DOFVERSION=300 -DEXTBRANCH=0 -DXVERSION= -I/waves2Foam/lnInclude -I/waves2FoamSampling/lnInclude -I -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/waveFoam.o -L/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib \ -limmiscibleIncompressibleTwoPhaseMixture -lturbulenceModels -lincompressibleTurbulenceModels -lfiniteVolume -lfvOptions -lmeshTools -lsampling -L -lwaves2Foam -lwaves2FoamSampling -L -lgsl -lgslcblas -lOpenFOAM -ldl \ -lm -o /opt/openfoam30/platforms/linux64GccDPInt32Opt/bin/waveFoam /usr/bin/ld: cannot find -lwaves2FoamSampling collect2: error: ld returned 1 exit status make: *** [/opt/openfoam30/platforms/linux64GccDPInt32Opt/bin/waveFoam] Error 1 Appreciate if anyone out there can help me out. Thank you very much. |
when i wclean and compile again, i get this error
Making dependency list for source file waveFoam.C could not open file relaxationZone.H for source file waveFoam.C due to No such file or directory could not open file externalWaveForcing.H for source file waveFoam.C due to No such file or directory could not open file readWaveProperties.H for source file waveFoam.C due to No such file or directory could not open file createExternalWaveForcing.H for source file waveFoam.C due to No such file or directory g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam30/src/transportModels -I/opt/openfoam30/src/transportModels/incompressible/lnInclude -I/opt/openfoam30/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam30/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/openfoam30/src/TurbulenceModels/incompressible/lnInclude -I/opt/openfoam30/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/fvOptions/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/sampling/lnInclude -DOFVERSION=300 -DEXTBRANCH=0 -DXVERSION= -I/waves2Foam/lnInclude -I/waves2FoamSampling/lnInclude -I -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c waveFoam.C -o Make/linux64GccDPInt32Opt/waveFoam.o waveFoam.C:55:28: fatal error: relaxationZone.H: No such file or directory #include "relaxationZone.H" ^ compilation terminated. make: *** [Make/linux64GccDPInt32Opt/waveFoam.o] Error 1 |
Good morning Kenric,
You are experiencing linking problems, because your libraries have not been compiled. You do not show that part of the compilation errors, so it is not possible to guide you. Kind regards Niels |
ask you the solution
I have the same problem. Could you please give me your solution. Thanks in advance.
Good morning,
I expect that the answer is given here: https://www.cfd-online.com/Forums/op...tml#post617581 - post #2 Kind regards, Niels |
Thank you for the reply.
I meet the problem when install your wave2Foam on OpenFOAM 3.0.1. i compile wavefoam then Making dependency list for source file waveFoam.C could not open file relaxationZone.H for source file waveFoam.C due to No such file or directory could not open file externalWaveForcing.H for source file waveFoam.C due to No such file or directory could not open file readWaveProperties.H for source file waveFoam.C due to No such file or directory could not open file createExternalWaveForcing.H for source file waveFoam.C due to No such file or directory g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/twoPhaseMixture/lnInclude -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/transportModels -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/incompressible/lnInclude -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/interfaceProperties/lnInclude -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/TurbulenceModels/incompressible/lnInclude -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/finiteVolume/lnInclude -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/fvOptions/lnInclude -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/meshTools/lnInclude -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/sampling/lnInclude -DOFVERSION=300 -DEXTBRANCH=0 -DOFPLUSBRANCH=0 -DXVERSION= -I/waves2Foam/lnInclude -I/waves2FoamSampling/lnInclude -I -IlnInclude -I. -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude -I/home/yao/OpenFOAM/OpenFOAM-3.0.1/src/OSspecific/POSIX/lnInclude -fPIC -c waveFoam.C -o Make/linux64GccDPInt32Opt/waveFoam.o waveFoam.C:55:28: fatal error: relaxationZone.H: no such file compilation terminated. /home/yao/OpenFOAM/OpenFOAM-3.0.1/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/waveFoam.o' failed make: *** [Make/linux64GccDPInt32Opt/waveFoam.o] Error 1 ===================================== ENVIRONMENTAL VARIABLES ===================================== EXTBRANCH=0 FOAMEXTENDPROJECT=0 OFPLUSBRANCH=0 WAVES_APPBIN=/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/bin WAVES_DIR=/home/yao/OpenFOAM/yao-3.0.1/applications/utilities/waves2Foam WAVES_GSL_INCLUDE=/usr/include WAVES_GSL_LIB=/usr/lib64 WAVES_LIBBIN=/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/lib WAVES_POST=/home/yao/OpenFOAM/yao-3.0.1/applications/utilities/waves2Foam/applications/utilities/postProcessing WAVES_PRE=/home/yao/OpenFOAM/yao-3.0.1/applications/utilities/waves2Foam/applications/utilities/preProcessing WAVES_SOL=/home/yao/OpenFOAM/yao-3.0.1/applications/utilities/waves2Foam/applications/solvers/solvers301 WAVES_SRC=/home/yao/OpenFOAM/yao-3.0.1/applications/utilities/waves2Foam/src WAVES_TUT=/home/yao/OpenFOAM/yao-3.0.1/applications/utilities/waves2Foam/tutorials WAVES_UTIL=/home/yao/OpenFOAM/yao-3.0.1/applications/utilities/waves2Foam/applications/utilities WAVES_XVERSION=0 WM_PROJECT_VERSION_NUMBER=301 ===================================== COMPILE LAPACK-3.3.1 ===================================== lapack-3.3.1 has already been compiled ===================================== COMPILE SPARSKIT2 ===================================== SPARSKIT2 has already been compiled ===================================== COMPILE OCEANWAVE3D ===================================== Pull changes from the OceanWave3D git repository ... *** Please tell me who you are. Run git config --global user.email "you@example.com" git config --global user.name "Your Name" to set your account's default identity. Omit --global to set the identity only in this repository. fatal: unable to auto-detect email address (got 'yao@yao-Precision-Tower-7910.(none)') stash。 OceanWave3D has already been compiled /home/yao/OpenFOAM/yao-3.0.1/applications/utilities/waves2Foam/ThirdParty ===================================== COMPILE FENTON4FOAM ===================================== fenton4Foam has already been compiled ===================================== COMPILE LIBRARY ===================================== '/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/lib/libwaves2Foam.so' is up to date. '/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/lib/libwaves2FoamProcessing.so' is up to date. '/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/lib/libwaves2FoamSampling.so' is up to date. '/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/lib/libwaves2FoamPorosity.so' is up to date. ===================================== COMPILE SOLVERS ===================================== ls: 无法访问'/home/yao/OpenFOAM/yao-3.0.1/applications/utilities/waves2Foam/applications/solvers/solvers301/*': 没有那个文件或目录 ===================================== COMPILE PRE-PROCESSING ===================================== make[1]: '/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/bin/faceSetToSTL' is up to date. make[1]: '/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/bin/relaxationZoneLayout' is up to date. make[1]: '/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/bin/setWaveField' is up to date. make[1]: '/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/bin/waveGaugesNProbes' is up to date. make[1]: '/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/bin/setWaveParameters' is up to date. ===================================== COMPILE POST-PROCESSING ===================================== make[1]: '/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/bin/postProcessWaves2Foam' is up to date. make[1]: '/home/yao/OpenFOAM/yao-3.0.1/platforms/linux64GccDPInt32Opt/bin/surfaceElevation' is up to date. ===================================== COMPILATION DONE ===================================== Quote:
Hello Jianxi Yao, Please install the dependencies (gfortran and git) in 8.1 from https://openfoamwiki.net/index.php/Contrib/waves2Foam and compile the solver by running ./Allwmake command. I believe this will solve your issue.
Dear Niels
I'm trying to install waves2Foam across openFoam 3.0.1. Everything seems to go right, (complilation, etc), but when i execute a case e.g bejiBattjes, everything is working (blockMesh, setwafields, setwaveParameters, waveGaugesNprobes), except the solver, waveFoam. I have this message in log file. /opt/openfoam30/bin/tools/RunFunctions: line 52: waveFoam: command not found. I would be gratefull if you could provide me some advice. Kind regards John |
