[waves2Foam] OpenFOAM 2.4.0: multiple problems sometime after installing |
June 2, 2016, 10:34 |
ArielJ
Rep Power: 10 |
Hi there,
I'm having sort of a weird problem using the surfaceElevation function type.. First of all, I have been using this successfully for months and have not changed my set-up. The problem is, I am running waveFoam on a cluster and when I try to use function objects, I get the error Code:
--> FOAM FATAL ERROR: Unknown function type surfaceElevation Valid functions are : 4 ( patchProbes probes sets surfaces ) From function functionObject::New(const word& name, const Time&, const dictionary&) in file db/functionObjects/functionObject/functionObject.C at line 92. FOAM exiting Note: I am running waveGuagesNProbes first and this does work on my own system. Anyone have this problem before? I am using OF 2.4.0. Thanks in advance! |
July 5, 2016, 06:40 |
Ack! Interfoam stopped working - symbol lookup error?
ArielJ
Rep Power: 10 |
Hi everyone,
I've been using interfoam for months now and I just tried to run a code with it and I got this error: interFoam: symbol lookup error: /home/ariel/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so: undefined symbol: _ZTIN4Foam14incompressible8RASModelE Where is this coming from?? I was working through a tutorial to create my own kEpsilon RAS model... could this have messed this up? I don't know how I managed to do that though because I didn't go into the lib folder at all and definitely not for interFoam.. I have no idea where to start looking for the problem and dont' want to mess anything else up! Huge huge thank you in advance for any advice on this stupid error |
July 5, 2016, 14:58 |
interFoam symbol lookup error??
ArielJ
Rep Power: 10 |
Hi there, I've done something very frustrating with the interFoam solver, or possibly the incompressibleRASModel library.. I'm getting this error when I try to use interFoam:
interFoam: symbol lookup error: /home/ariel/OpenFOAM/ariel-2.4.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so: undefined symbol: _ZTIN4Foam14incompressible8RASModelE Code:
wmake libso Code:
wclean RAS wmake libso RAS |
August 10, 2017, 08:39 |
Vedamt Chittlangia
Rep Power: 9 |
Were you able to fix this problem?
I did something and now am unable to fix it. |
August 10, 2017, 09:36 |
Vedamt Chittlangia
Rep Power: 9 |
Were you able to solve this? I face the similar problem.
February 10, 2020, 09:01 |
#6 | |
Arun Kumar
Rep Power: 6 |
I am also facing this same error when I try to run my program on the cluster. Did you happen to find a solution? Thanks, Arun. |
February 12, 2020, 02:17 |
renos
Rep Power: 6 |
Dear Pablo,
I am trying to simulate wave breaking in a monopile using OlaFlow. I am using the library libforces.so provided by OpenFoam but a have a lot of difference in the magnitude of Force. All the other things (mesh / boundary conditions is the same ). Below is the function that I am using in the controlDict file. Also the diameter of the monopile is D=0.7 m / H=1.3 / T = 4.0s / d=3.8 m. What is going wrong ? forceCylinder { type forces ; libs ("libforces.so"); enabled true; patches ("cylinder"); pName p; UName U; rho rhoInf; rhoInf 1; CofR (0 0 0); log true; writeControl timeStep; writeInterval 1; } Thanks you very much for your time, Kind regards Renos |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
Problems compiling custom interPhaseChangeFoam with OpenFOAM 2.4.0 | abdoli | OpenFOAM Programming & Development | 1 | October 6, 2016 08:46 |
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on CentOS-6.6-x86-64 | Milan2013 | OpenFOAM Installation | 24 | November 28, 2015 15:05 |
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on Ubuntu 12.04 | arieljeds | OpenFOAM Installation | 6 | August 19, 2015 07:39 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
