[Sponsors] | |||||
[waves2Foam] Difficulties in creating different relaxation zones |
CH Xu
Rep Power: 14 ![]() |
Hi Niels,
I've been trying to modify the tutorial case "waveFlume", and encounterred this problem: I was trying to use a larger mesh size for the relaxation zones, i.e.: the entire length of the domain was 18m and the first and last 5m was relaxation zone, I was trying to use a mesh size of 1cm*0.5cm in the section of 5 to 13m, and use a mesh size of 2cm*0.5cm inside the relaxation zones. I did this using three mesh blocks in blockMeshDict (please see attached). The problem is now waves2Foam seemed to recognize the end of the first block, or the beginning of the second block (at x=5m) as the outlet relaxation zone, and no wave can propagate into x=5 to 13m domain. Can you help me to determine where the problem is? I attached the blockMeshDict file for your reference. Code:
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
( 0 -0.4 0 ) //0
( 10 -0.4 0 ) //1
( 0 0.2 0 ) //2
( 10 0.2 0 ) //3
( 0 -0.4 0.1 ) //4
( 10 -0.4 0.1 ) //5
( 0 0.2 0.1 ) //6
( 10 0.2 0.1 ) //7
( 10 -0.4 0 ) //8
( 11 -0.4 0 ) //9
( 10 0.2 0 ) //10
( 11 0.2 0 ) //11
( 10 -0.4 0.1 ) //12
( 11 -0.4 0.1 ) //13
( 10 0.2 0.1 ) //14
( 11 0.2 0.1 ) //15
( 11 -0.4 0 ) //16
( 18 -0.4 0 ) //17
( 11 0.2 0 ) //18
( 18 0.2 0 ) //19
( 11 -0.4 0.1 ) //20
( 18 -0.4 0.1 ) //21
( 11 0.2 0.1 ) //22
( 18 0.2 0.1 ) //23
blocks
hex (0 1 3 2 4 5 7 6) ( 1000 120 1 ) simpleGrading (1 1 1)
hex (8 9 11 10 12 13 15 14) ( 200 120 1 ) simpleGrading (1 1 1)
hex (16 17 19 18 20 21 23 22) ( 700 120 1 ) simpleGrading (1 1 1)
edges
patches
patch inlet
(0 4 6 2)
wall bottom
(0 1 5 4)
(8 9 13 12)
(16 17 21 20)
patch outlet
(17 21 23 19)
patch atmosphere
(2 3 7 6)
(10 11 15 14)
(18 19 23 22)
empty frontBack
(0 1 3 2)
(8 9 11 10)
(16 17 19 18)
(4 5 7 6)
(12 13 15 14)
(20 21 23 22)
mergePatchPairs
Conghao |
Niels Gjoel Jacobsen
Rep Power: 38 ![]() ![]() |
Hallo Conghao,
Your blockMeshDict does not match what you describe in terms of coordinates. Please use relaxationLayout to visualise your relaxation zones. That would enable you to debug the problem. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lets talk about relaxation factor optimization | chriss85 | OpenFOAM Running, Solving & CFD | 36 | April 3, 2025 16:45 |
| [waves2Foam] Trying to implement relaxation zones in waveDyMFoam | gautami | OpenFOAM Community Contributions | 4 | March 3, 2017 11:10 |
| Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
| [ICEM] Problem in creating different zones in ICEM-CFD | samurai_01 | ANSYS Meshing & Geometry | 2 | November 28, 2012 13:41 |
| Creating Zones from the stl file | johnchang | OpenFOAM | 0 | June 3, 2010 09:39 |
