Reflection analysis for a flat wave flume
Hi All:
I am doing a reflection analysis for a flat wave flume. I use stokes first order wave with H = 0.02 and T = 2s, the surface elevation seems reasonable but the reflection coefficients goes to 1.27 which is obvious wrong.... and I can not see why a0 goes to infinite... I attach the postprocessing file and the results: Code:
deleteParentOutputDirectory false; Code:
1 0.0145989 Code:
1 -0.0279252 Best regards Hao |
Good evening Hao,
Your mean surface elevation (frequency index 0) is -6.25e+13, so you are probably doing something wrong. I cannot, however, come with any suggestions for improvements based on your information. Kind regards, Niels |
Hi Niels:
Does this utility only use this input file or it also reads some data from other files like waveParameters? I check the interpolated surface elevation and there is one file called 'surfaceElevation_indexXYZ.txt' it looks like: Code:
0 -5e-09 5e-08 1.49418 Best regards Hao |
Hi Hao Chen,
I'm new in using OpenFOAM and I'm trying to perform the 2DFFT reflection analysis and the resultant value is greater than 1 as in your case (even if you used the LS method). Did you understand how to perform this analysis?? Can you help me? Giusy |
could somebody help me to calculate reflection coefficient? I did reflectionAnalysis2DLS, but I don't understand what is exactly the leftGoing and rightGoing results:confused: It would be very appreciated if somebody could send me the postProcessingPropertiesdictionary and tell me how to obtain reflection coefficient from the output! Sanaz |
