[waves2Foam] OF 2.2, problems using waveFoam, command not found |
December 9, 2015, 13:49 |
Niels D
Rep Power: 10 |
For the moment i am running OpenFoam-2.2.2 and tried to use waves2Foam today. When compiling the source code for waves2Foam no problems occur. When i am trying to run the tutorial waveFlume, the pre-processing commands like blockMesh, ... do work. But the command waveFoam does not work. The error i am getting when using ./Allrun is: niels@niels-HP-Pavilion-17-Notebook-PC:~/OpenFOAM/niels-2.2.2/applications/utilities/waves2Foam/tutorials/waveFoam/waveFlume$ ./Allrun Running blockMesh on /home/niels/OpenFOAM/niels-2.2.2/applications/utilities/waves2Foam/tutorials/waveFoam/waveFlume Running waveGaugesNProbes on /home/niels/OpenFOAM/niels-2.2.2/applications/utilities/waves2Foam/tutorials/waveFoam/waveFlume Running setWaveParameters on /home/niels/OpenFOAM/niels-2.2.2/applications/utilities/waves2Foam/tutorials/waveFoam/waveFlume Running setWaveField on /home/niels/OpenFOAM/niels-2.2.2/applications/utilities/waves2Foam/tutorials/waveFoam/waveFlume Running waveFoam on /home/niels/OpenFOAM/niels-2.2.2/applications/utilities/waves2Foam/tutorials/waveFoam/waveFlume Running postProcessWaves2Foam on /home/niels/OpenFOAM/niels-2.2.2/applications/utilities/waves2Foam/tutorials/waveFoam/waveFlume /home/niels/OpenFOAM/OpenFOAM-2.2.2/bin/tools/RunFunctions: line 42: 22079 Segmentation fault (core dumped) $APP_RUN "$@" > log.$APP_NAME 2>&1 When only using the command waveFoam, the error is that the command can not be found. The other pre-processing commands work just fine. Thanks in advance |
December 10, 2015, 12:18 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good afternoon,
@Slein: If waveFoam does not exist, it means that not everything went as smoothly in the compilation process as you think. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. Last edited by wyldckat; August 25, 2018 at 13:09. Reason: removed answers to other posts that were on the main thread |
Display Modes | |
[Gmsh] Insatlling gmsh from the source code-issue? | CFD-Lover | OpenFOAM Meshing & Mesh Conversion | 20 | June 12, 2018 07:39 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 06:29 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 17:14 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 05:41 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
