[waves2Foam] Turbulence problems, possibly due to density issues |
December 5, 2015, 08:34 |
#1 | |
Aloha
Rep Power: 10 |
Hi ngj,
Thanks for the powerful tool. I got the desired result when I generated wave using laminar.But when i switch to turbulence model,say RNG k-epsilon,the surface elevation at a certain probe decays significantly.I think the problem maybe the missing of density term in the k&epsilon equations afterI read your phd thesis (N. G. Jacobsen 2011. ) and the post below: Quote:
So is there any guide to modify the turbulence equations as I am not familia with the C++.. Thank you in advance Aloha Last edited by wyldckat; August 25, 2018 at 12:18. Reason: changed post number to quoted post |
December 6, 2015, 15:20 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good evening,
@Aloha: No, there is no guide available that described how to include the density in the turbulence closure. Please verify that the scale of your problem actually requires a turbulence model. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. Last edited by wyldckat; August 25, 2018 at 12:18. Reason: removed answers to other posts that were on the main thread |
Turbine simulation and turbulence parameters: Floating point exception issues | DaveR | OpenFOAM Running, Solving & CFD | 4 | December 1, 2016 11:19 |
Turbulence model issues | chmurillor | FLUENT | 0 | July 15, 2014 04:34 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Convergence problems with SSG turbulence model | Ram | CFX | 1 | June 19, 2006 10:08 |
