[waves2Foam] Function object to extract overtopping rate - how to use it?
Like Tree3Likes
  • 3 Post By ngj
Old   March 5, 2015, 08:03
Default Function object to extract overtopping rate - how to use it?
Hao Chen
hchen is on a distinguished road
Hi All:
I notice that waves2Foam has a runtime function object to extract overtopping rate, anybody has used this function object? It seems that I should define a face zone where the overtopping rate across it can be extracted?
hchen is offline   Reply With Quote
Old   March 5, 2015, 12:43
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Yes, it has been used to evaluate the overtopping in our paper Jensen, Jacobsen and Christensen (2014); more details can be found on the wiki.
Yes, you need to define a faceSet or faceZone (please check the source) and it comes with some strict naming conventions. You should be able to check that in the source code, as I do not have access to it right now. Naming convention is chosen for easy evaluation of multiple sets/zones.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   May 21, 2015, 12:12
Smile
William Yan
William Yan is on a distinguished road
Kind regards,
Niels
Hi Niels,
I am working on the overtopping too and recently I got a problem of naming the faceZone. It will be very helpful if you can provide me an example of overtoppingDict. Thanks a lot!
William Yan is offline   Reply With Quote
Old   May 25, 2015, 08:09
ngj
Hallo William,
In controlDict you add in functions:
    overtopping0
        type overtopping;
        functionObjectLibs ( "libporosityModule.so" );
        outputControl   timeStep; // Alternative: outputTime
        outputInterval  1;
And then you create a corresponding faceZone with the same name, e.g. overtopping0. This you can do with topoSet. In topoSetDict in order to create a faceSet:
        name    overtopping0;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
                box  (105.8 14.04 0) (106.2 35 0.2);
And then convert this to a faceZone by:
        setsToZones -noFlipMap
Kind regards,
Niels
P.S. Thanks to Bjarne Jensen for the example.
Jose_J, ethan13 and Metqeu like this.
Old   September 10, 2019, 03:15
Default How to read Overtopping output
Carlos Garrido
carlosar is on a distinguished road
Hello Niels and others,
Can you tell me how to read the overtopping output?. As I know the overtopping.dat contains a 3 component vector with an instantaneous overtopping volume, but I don't understand the meaning of this three vector component.
Can anyone give me some tips about this.
Thank you,
carlosar is offline   Reply With Quote
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
