[Sponsors] | |||||
[Other] sedFoam: two-phase flow sediment transport model |
#101 |
Rep Power: 5 ![]() |
Thank you very much for your previous answer. I found a less aesthetic but sufficient workaround by computing the wallDistance using checkMesh -writeAllFields and the wallDist keyword in fvSchemes.
I am trying to simulate a case of periodic hills with a given sediment concentration throughout the domain, in order to analyze sediment distribution in different regions as well as erosion and deposition fluxes at the bed. So far, I have been computing div(phi.a) to quantify erosion/deposition at the surface and I am not sure that this is the proper way to do this. I noticed that the code includes dedicated quantities called Erosion and Deposition, which are computed in createFavreAveraging.H. When I run the simulation with FavreAveraging activated, I obtain fields like betaSqrUbMean, UbMeanF, etc., but I do not get Erosion or Deposition. Upon inspecting calcFavreAverage.H, I saw that the lines Erosion.write(); and Deposition.write(); are commented out. Since these quantities are of primary interest in sedimentation studies, I don’t understand why they are not computed by default. I may have missed something. Could someone explain how to save the output related to deposition and erosion fluxes so that I can visualize them in ParaView? Thanks a lot! |
#102 |
Eduard Puig Montella
Rep Power: 6 ![]() |
In the current code, “Erosion” and “Deposition” are only declared but they are never assigned anywhere in the loop so they remain zero. We might add this feature in the future, but at this point you can't quantify erosion/deposition using these variables.
For a resolved mobile granular bed, a better way to quantify erosion/deposition is either: a) track bed/interface position using an isosurface of alpha (for instance alpha=0.2) and compute Δbed elevation over time (you can do that with paraview, fluidfoam or adapting some of the postprocessing scripts), or b) compute solids flux across a reference surface (alpha*Ua·n (also doable with fluidfoam and paraview)) near the bed. This should be more appropriate than using div(phi.a), which measures local accumulation/depletion of sediment due to transport in any direction. |
#103 | |
#104 | |
Julien CHAUCHAT
Rep Power: 15 ![]() |
Dear zjy, Thanks for your question.We have recently developped a methodology and postprocessing tools to do that and much more like computing bedload and suspended load fluxes as well as reconstructing Exner equation terms. This work has been published recently in IJMF and it can be found here: https://doi.org/10.1016/j.ijmultiphaseflow.2025.105457 or alternatively here for an open-access version : https://cnrs.hal.science/IGE/hal-05299771v1 As usual, the potsprocessing tools are also available freely online : https://github.com/SedFoam/exnerDiagnosis.git By the way, I am curious to learn more about your research. Don't hesitate to give us some feedback about your work. Cheers, Julien |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
| use mixture model to simulate two-phase flow with phase change | dxm2008 | Fluent Multiphase | 5 | September 7, 2016 15:15 |
| Free Surface Flow with Sediment Transport | M. Riffai | CFX | 3 | September 5, 2013 10:45 |
| How do model two phase granular flow in Porous media? | bahman | FLUENT | 1 | December 6, 2012 05:39 |
| Transitional Flow Shear Stress Transport (SST) k-omega Turbulence Model | josechen | FLUENT | 0 | July 20, 2011 17:06 |
