floating object inside the flume tutorial with interDyMFoam
hi everybody
I'm completely new to openfoam and CFD world, so please be patient if my request seems stupid for studying purposes I've to simulate a wavetank including a floating plate. During my researches I've found that waves2foam is more or less what I need, but I don't know what I've to do to add the floating object, for example to the waveflume tutorial. I'm running openfoam 2.3.0, and I've found the tutorial linked here (https://sites.google.com/site/jordim...ic-mesh-motion) but it's not working at all, since it's designed for OF 1.7.1 could you please help me? tnx in advance Best Regards |
hi everybody
I think I've coupled waves2foaam with interdymfoam (i'm a newbie), so I've tried to put a floating object inside the flume tutorial, but the simulation crashes immediately:( this is the error I get Quote:
https://www.dropbox.com/s/z6h5nhm8sr...me.tar.gz?dl=0 please help me, I'm stuck and I don't know how to solve this situation thanks in advance best regards |
@Rising : I ran your case and found the same error, although changing the time scheme seems to change the error time. So I tried to output what happens before the crash, and it seems your floating object is not well defined, the wave field just crashes into it: I don't know what happens exactly but the Courant number explodes and the maximum water fraction is way above 1. It looks like and obstacle.
I have no solid advice, but have you tried either 1) your waveDymFoam on a known tutorial like waveFlume 2) to put a floating object using just waveFoam (or interFoam)? What were the results? Best, Pablo |
